Funally got my bike dyno tuned after doing the 103ci, w/251 cams. I ended up getting 90hp with 100.? torque, not as good as others I've seen posted here but I'm happy with the build. Thanks for all the replys.
capt42a
Capt43a,
Did you post your dyno sheet? Could be the pipes or maybe the dyno pull did not go to 6200 RPM. There should be a few more ponies in there. Air cleaner? Did you use the Cometic .030" head gasket?
Just want to give you a few things to think about to maybe pull those last few ponies out of the engine.
Hey Guys, I'm doing a similar build on my '09 Street Glide. I went with the 103 SE kit, pistons, jugs, Intake, etc., no heads though. I'm going to run the SE head pipes that came with the kit, and V&H Monster Ovals. The kit also came with 255 cams......I've read the replies concerning the 07. My question is on the '09, since the 6 speed is geared differently would I be better off with the 251? I don't intend on racing, but do intend on gettin on once in a while. I do carry the wife on long rides. I'm looking for more power on the highway (passing) as well as the ocassional quick take-offs. Any input on which cam to use? Thanks
