too cheap true duals/
Seems like you cut the crossover pipe in two places and insert plugs into each of the cut off ends. Put the heat shield back on and no one can tell.
This seems almost too easy - could it possibly work? How would you know if the backpressure was OK in each exhaust?
Here's a pic of my '78 FLH. The quality ain't that great, but the head pipes are stock but have been modified to make 'em into an old style lookin' 2 into 1, with the straight fishtail extension.
This was done similar to the method y'all are talking about. Where the left side pipe connected to the rear I brazed a GM freeze plug in. Could've done it without brazing as it was an expandable type. Next I had to cut the section of pipe coming from the rear head to the front pipe in two and grind out the restrictor that was in there. Then that pipe was welded back together and my 2 into 1 was complete. The heat shields covered up the weld.
What that kit does is provide you with two plugs, right? Head to an auto parts store and get a couple freeze plugs. Won't cost but a couple bucks. Cut the crossover pipe as close to the head, and as close to the front pipe as possible, but still leaving enough to install the freeze plugs. It'll work fine, and if you want a bit deeper rumble/more noise, get a different set of mufflers.
If you're running mufflers you'll have the needed back pressure. If you add straight pipe extensions then add a couple of these.
They're copper pipe reducers available at any hardware store. Put 'em in the head pipes just before the straight pipe extension. Then add these adjustable lolliepops for some back pressure.
Here's a pic of a lolliepop up my drag pipes.
You can tune the lolliepops to get the most out of 'em. There's a how-to down in the DIY section. It's titled something like Drag Pipe How-To.
You can't hardly even see the crossover on an '05 so why change it? The pipes are designed with the crossover in mind, and it is a big aid to performance. Leave it!
