Smoke under heavy acceleration..
Old Apr 17, 2006 | 04:37 AM
Crimson's Avatar
Crimson
Default Smoke under heavy acceleration..
Last year, while riding in groups, my friends indicated I had a stream of smoke coming from my bike occasionally while riding, not real noticable but enough that it caught their attention. This year, they tell me they smell a burning oil type of smell while riding behind me, and several times under hard acceleration they said a big brown cloud came out.. I can't see it while driving, but thats how they described it. The bike is a 1996 Road King Classic with about 18,000 miles on it. I am going to bring it in to the dealer this week, but want to get some ideas of what people think it might be before I have them check it out.. the better informed I am the better!
Most of my friends say the rings are going, which seems to be too soon on a bike with 18,000 miles, although it is nearly 10 years old. I don't have a real good history of the bike but the previous owner did store it in a climate controlled storage area at the dealer each year, and did have regular maint. done as far as I can tell.. so I don't think it was abused. I did switch the bike from stock HD oil to Mobile 1 V-Twin, and some peopple say thats not a smart thing to do to an older bike? I dunno, I feel better with full Synth. I don't notice any major oil loss, its been maybe 1500 miles since my last oil change and the dipstick is dead on where its supposed to be.
Any ideas here? I realize the only answer may be to bring it in and have them look at it but opinions are appreciated.
Old Apr 17, 2006 | 08:50 AM
websterdan's Avatar
websterdan
Default RE: Smoke under heavy acceleration..
Pull and check the plugs, sounds possibly rich to me. However, I'd also check the fluid levels in the Trans and Primary. If your oil level is fine, then doubt it's a ring thing.
Old Apr 17, 2006 | 09:23 AM
tripl8's Avatar
tripl8
Valve guide seals.....
Old Apr 17, 2006 | 11:04 AM
BigGeorge's Avatar
BigGeorge
I agree with tripl8 sounds like valve guide seals. Usually when upshifting you will get a "puff" of blue smoke everytime you shift. This will be especially noticable under hard acceleration. Usually if you have bad piston rings the engine will smoke all the time even at idle. Your choice of oil will make little difference. Once the oil gets past the valve guides into the combustion chamber its burned and pushed out the tail pipes so your friends riding behind you can enjoy it too.................BG
Old Apr 17, 2006 | 03:59 PM
HDWRENCH's Avatar
HDWRENCH
Well the big brown puff would be fuel, a bit rich . The oil smell could be seals, rings, Do a compression check, a leak down check is even better. Many times I see that the cylinder has a few small marks in the cyinder allowing just enough oil to smoke a bit but not really use enough to see from oil change to the next. It really does not take much oil to get into the chamber to smoke and for other to see out the pipe.
Old Apr 17, 2006 | 04:37 PM
lowglide88's Avatar
lowglide88
Check your pipes...you'll be able to tell if its oil or runnin rich...I'll agree with the valve guide seals...my buddy's sportster did similar thing.
Old Apr 21, 2006 | 03:53 PM
LOTHAR's Avatar
LOTHAR
ORIGINAL: HDWRENCH
Hey wrench, I just had my 2005 1200C Stage oned. I have the fuel puff thing and a faint smell of fuel when I put the bike away hot. I am not using excess gas and when I called my service guy, he said check the plugs when the bike is hot and look at the color. He seemed to think that if it is just running a tad rich that it was better than leaning it out. It runs better and has more zip in all gears and rpm's. I am reluctant to monkey with it. Any suggestions? I do not have and have never had any residue anywhere from my air cleaner.
Fastfwd
Engine Mechanical Topics
49
Jul 27, 2020 01:57 PM
brandss
Aug 28, 2017 02:15 PM
Ozark Joe
Dec 22, 2015 02:59 PM
RCermak
EVO
Nov 22, 2013 03:13 PM
watindes
EVO
20
Apr 16, 2012 07:07 PM
