S&S Super E
Old May 2, 2006 | 12:00 PM
gary99z28's Avatar
gary99z28
Default S&S Super E
I'm trying to tune my fathers 1200 Sportster and I'm having trouble with throttle response. The bike runs well and pulls like a motherF#@$er but when the throttle is bliped from idle, it has a hesatation. It's not too bad but I want to get it right on. What do you guys think. And thanks for the help.
Old May 2, 2006 | 12:35 PM
fxstcguy98's Avatar
fxstcguy98
Default RE: S&S Super E
You need to add more accelerator pump until it stops hesitating. You should find it on the right side of the carb, turn it counterclockwise.
Old May 2, 2006 | 04:01 PM
gary99z28's Avatar
gary99z28
I did adjust it and this is where it runs the best. I checked the plugs and after 100 miles they look brand new so I will go up with the intermediate jet and re-adjust. If I make it richer, hopefully it will end this problem.
Old May 4, 2006 | 12:40 PM
Spectrexx's Avatar
Spectrexx
Have you adjusted everything according to the S&S instructions? You can download them from their site. A dyno run would help a LOT, if there is one in your area. How old is the carb? It might need a rebuild, or you might have an intake leak that is causing problems. It does sound like an accel pump adjustment, though. One thing I have done to most of my S&S carbs is to add the Yost Power Tube. It completely eliminated all hesitation that some of them have, even when adjusted correctly. It's something to consider.
Trevor Noyes
Carburetor Related
May 21, 2019 07:55 PM
KingPinVinny
Mar 15, 2012 08:48 PM
hog85
EVO
18
Aug 26, 2011 08:09 AM
straydog13
Ironhead
Jun 3, 2008 03:11 PM
nemesistech
Jul 25, 2006 12:55 PM
