Centering Oil Pump
Old Apr 13, 2009 | 09:55 AM
Hooter1's Avatar
Hooter1
Default Centering Oil Pump
Putting my '07 Heritage back together after a cam change and wondering if I need to do the spin the real wheel method to center the oil pump if I've already got the (2) tapered aligning pins that can be put in the pump holes diagonally. Also, I'm assuming that the (4) oil pump bolts get put in after the cam plate has already been torqued back into the cases?
Old Apr 13, 2009 | 11:24 AM
KumaRide's Avatar
KumaRide
Your manual should have the directions when using those pins. I believe with the pins you do not need to spin tire. And yes, align pump after cam plate is installed. fwiw - I aligned mine without the pins. Someone spun the rear tire while I slowly tightened down the 4 bolts.
Old Apr 13, 2009 | 03:46 PM
Hooter1's Avatar
Hooter1
I'll check my manual tonight. If I do need to turn the motor over, is it OK to do this by turning the motor over with the crank bolt? I've got the bike on a lift and don't have anything to raise the a$$ end of the bike up with. Since the pushrods aren't yet in(got adjustables) thinking it should turn over pretty easy. Best case, I can just use my tapered pins and not even have to do this.
Old Apr 13, 2009 | 05:21 PM
KumaRide's Avatar
KumaRide
I would not turn the crank bolt several times, I mean several times... to center oil pump. And, the wheel should be turned continuously while tightening the four bolts. With the pins, you should not have to turn wheel. If you do, remove plugs, borrow a jack or something, and get some help. It is not worth rushing the job and having pump issues after it is back together.
Old Apr 13, 2009 | 05:25 PM
rbabos's Avatar
rbabos
I doubt very much it's necessary to spin the engine with the correct locating pins. Centering with the wheel would be more hit and miss in my view for acurate center.
Ron
Old Apr 13, 2009 | 10:57 PM
Bad Disposition's Avatar
Bad Disposition
A damaged oil pump is not a pretty sight! BE SURE BEFORE YOU FINISH IT UP!
Old Apr 13, 2009 | 11:24 PM
Kbore's Avatar
Kbore
*DO NOT turn the motor with the crank or cam bolt.
*Torque 6 allen heads on cam plate in pattern shown in manual.
*Install 2 alignment tools in holes 1 and 2 of oil pump.
*Start 2 allens in holes 3 and 4.
*While rotating...tighten alignment tools and allens until snug, using pattern on plate.
*Using same tightening sequence, tighen tools and 2 allens to 40-45 in-lbs.
*Remove alignment tools- replace with allens.
*Final torque to all four screws to 90-120 in-lbs, using pattern on plate.
Old Apr 14, 2009 | 03:25 PM
rbabos's Avatar
rbabos
Hmmm. Wonder how engine shops do it or the factory if you can't use the engine bolt. Just curious.
Ron
Old Apr 15, 2009 | 02:00 AM
wurk_truk's Avatar
wurk_truk
maybe use the output shaft? I was wondering that TODAY myself...
Old Apr 18, 2009 | 07:17 PM
Kbore's Avatar
Kbore
...and what would be the problem with turning the rear wheel?
