Carb Jetting
Old May 4, 2009 | 01:14 PM
asm481's Avatar
asm481
Default Carb Jetting
Thanks for looking in. I removed my stock carb to replace cracked breather hoses. As long as I had it off I took a peak to see what the jet sizes are. I bought the bike (2002 FXD) last fall and was told it had a complete Stage one on it. The a/c and V&H pipes were obvious but never liked the tune. A little decel pop and every once in a while coming off idle a carb fart. The jets in it right now are 45 and 190. Is that stock? should I go the next size up on the pilot jet? Acceleration is good as it is, not looking to drag race! Oh yea, I just drilled out the mixture screw and have read on how to tune there. Is that maybe all I need? Plugs so far have been very white.
Old May 4, 2009 | 05:38 PM
asm481's Avatar
asm481
No replies!!
Least now I am a prospect!!!!
Old May 4, 2009 | 06:07 PM
Dave54's Avatar
Dave54
http://www.nightrider.com/biketech/hd_cv_mods.htm
everything you need to know
Old May 4, 2009 | 06:45 PM
buckmc's Avatar
buckmc
Sounds stock to me
Old May 4, 2009 | 08:17 PM
schmeg's Avatar
schmeg
Go with a 46 pilot and an N72D needle from Harley. It used to be on the early 90's FXD cop bikes. Adjust pilot as required. Start at 1.25 turns out. I'm assuming the carb is unadulterated (no Dynojet kit with a drilled out slide). If you want to throw more money at it, call Bobby Wood and get his KT-1 needle. Works great. More money though. Better yet, his full up carb modding is second to none.
Old May 16, 2009 | 01:50 PM
96 Wide Glide's Avatar
96 Wide Glide
I tryed everything to eliminate that occasional ' carb fart ' with my C.V carb, including changing all intake seals, twice. Never did!
This winter I replaced it with a Mikuni HSR 42, cured it completely .
Old May 16, 2009 | 07:32 PM
Crazy Canuck's Avatar
Crazy Canuck
Diddo!!
Originally Posted by 96 wide glide
i tryed everything to eliminate that occasional ' carb fart ' with my c.v carb, including changing all intake seals, twice. Never did!
This winter i replaced it with a mikuni hsr 42, cured it completely .
DKVIKING
Dec 28, 2015 10:12 PM
Big Pap
Dec 1, 2012 10:49 PM
jm04
Jul 21, 2010 03:13 PM
bryon857
Ironhead
Feb 21, 2008 06:56 PM
Sally88
Jul 19, 2006 06:01 PM
