Question about back fire.
Old Apr 22, 2005 | 11:31 PM
softale_03's Avatar
softale_03
Default Question about back fire.
I have 2003 Softail Standard fuel injected. I have recently developed a back fire when raising the RPM'S to downshift. Can anyone give me some ideas on whats causing this and how I may be able to fix this...Thanks Henry
Old Apr 22, 2005 | 11:39 PM
HarleyRon's Avatar
HarleyRon
1st Gear
Default RE: Question about back fire.
Have you made any recent changes to bike such as new exhaust or air cleaner? If not, look for intake leak, Harley's intake seals are notorious for leaking.
Old Apr 23, 2005 | 03:35 AM
John TN's Avatar
John TN
ORIGINAL: HarleyRon
I agree with you, since the backfire is on decel only.
Old Apr 23, 2005 | 11:22 AM
softale_03's Avatar
softale_03
no recent changes. I had the exhaust put on prior to delivery. Will this leak hurt my bike by running it before fixing it or is this something I shound have harley fix ASAP?
Old Apr 23, 2005 | 11:52 AM
John TN's Avatar
John TN
ORIGINAL: softale_03
You can check for intake leaks, by spraying carb cleaner with the engine idling around the intake manifolds, if the idle increases you have a leak, just don't spray it near the air filter, you will get a false reading, spray from the opposite side of the bike from the air cleaner. Also check the exhaust flange nuts at the cyclinders and make sure they are tight, sometimes I have found them loose.
Old Apr 23, 2005 | 06:51 PM
softale_03's Avatar
softale_03
Thanks for the help Ill see what I can find...
imjwag
EVO
17
Oct 31, 2014 08:53 PM
c-note
Apr 29, 2014 10:12 PM
mke125125
Feb 4, 2010 02:23 PM
GymChamp
Nov 26, 2009 02:56 PM
lonewolf57
Jul 19, 2006 06:03 PM
