Air leaking IN or exhaust leaking OUT ?
Popping can occur if there is a leak where the mufflers are clamped to the header pipe.
You may also have an intake leak, and to check that you can carefully spray some carb cleaner at the intake manifold with it running. (you can also use a propane torch). If there is a change in the idle speed, you have a leak. Be careful not to spray into the a/c, that will give you a false result.
Your popping can also be caused by the tuning of the bike, with or without any leaks.
Jus' remember, it is always based on 'energy'.
Darkness is nothing more, than a lack of "light".
Likewise, cold, is a lack of "heat" energy.
THIS is what confuses the chit outta peeps, when you try to 'edumacate' them, on geothermal heating and cooling systems.
"Well, how can that 53* H2O, 'heat' the air in the house???"
OOPS, OP, you can get BOTH, as posted.
Likewise, the 'popping', can be traced to more than one, prob.
With that aside, decel popping can be cured by removing fuel in the zero throttle position in the lower rpm ranges. (sometimes adding fuel will also cure the problem). It's not that often that sealing a leak solves decel pop.
