Throttle position help with PCIII!!
Old May 20, 2006 | 09:11 PM
99RoadKing's Avatar
99RoadKing
6th Gear
Default Throttle position help with PCIII!!
I have been on hold with DynoJet for more than 2 hours off and on today! I changed my closed throttle position from 5% to 0% and now I have popping on decel which I did not have before. Power Commander has instructions for resetting to Zero but I don't know how to raise it back to 5% to get rid of the popping. Anyone know how to do it??
Old May 21, 2006 | 11:20 AM
Uncle Peepers's Avatar
Uncle Peepers
Default RE: Throttle position help with PCIII!!
If the TPS is set at zero and you have decel popping, the problem isn't with the TPS setting. It's simply revealing a problem elsewhere. First, make sure your idle(s) are set properly. If they're too low, you'll get popping. If they're okay, trying richening the mix at the rpm range and throttle percentage where the popping occurs. That should fix it.
Uncle Peepers
monsterglide2008
Sep 5, 2009 07:32 AM
mja52403
Sep 10, 2008 01:39 PM
SC-Longhair
Jul 4, 2008 05:42 PM
sifularson
Oct 13, 2007 12:16 AM
sifularson
Oct 7, 2007 09:14 PM
