help with exhaust install
Old Jul 10, 2009 | 09:09 PM
MoonCricket's Avatar
MoonCricket
Default help with exhaust install
I pulled of my pipes (vh bss) to do a little work to my bike, now when I went to re install the pipes today I noticed the pipes will not seat inside the exhaust ports with the new exhaust gaskets installed, instead the pipes just barely butt up to the gaskets. Do the pipes seat inside the exhaust ports and crush the gaskets when torqued down or do I have the wrong size exhaust gaskets. I have the stock hd gaskets with the tapered side facing the pipes. i am worried about exhaust leaks. also it seems like the best way is to install the pipes is to first the pipes, then install the heat sheilds. am I off base, any advise...Thnx
Old Jul 10, 2009 | 09:42 PM
99embrey's Avatar
99embrey
Maybe I misunderstood your post, but it sounds like you may have your gaskets in backwards. The gaskets taper "in" toward the heads.
Old Jul 10, 2009 | 09:48 PM
MoonCricket
the tapered end face the heads? so the thick end face the pipes? that may be my prob
Old Jul 10, 2009 | 10:41 PM
99embrey's Avatar
99embrey
The thinnest edge (widest hole) goes toward the pipes. The gasket more or less "funnels" into the head
Old Jul 11, 2009 | 09:52 AM
MoonCricket
thats the way i have it and i have the problem mentioned above
Old Jul 12, 2009 | 09:31 AM
MoonCricket
was hoping for a little more feedback...
Old Jul 13, 2009 | 12:38 PM
Dalton's Avatar
Dalton
You have the gaskets in right. Just instal the pipes, and tighten to about 24ft pounds (snug) and then ride a bit to heat everything up then come back and sug them up again and that should be it.
Old Jul 13, 2009 | 02:00 PM
genedjr's Avatar
genedjr
You did take the old gaskets out right? That will cause no end if problems if you have 2 gaskets in there.
...gene
Old Jul 13, 2009 | 02:04 PM
anubisss's Avatar
anubisss
I was helping a friend with an install a couple of weeks ago and had the same issue. It was nearly impossible to get the exhaust flange over the studs. After much hassle, we reused the old gaskets although I know this is not suggested practice. I always use a screwdriver to push the edge of the gaskets in as far as they will go to make sure they are seated properly as well.
mcdaniel52761
Aug 27, 2010 09:38 PM
MoonCricket
Jul 15, 2009 02:17 PM
rockon
Dec 8, 2008 09:00 AM
LabCat
Apr 7, 2008 11:13 PM
Gary C.
Sep 16, 2005 07:53 AM
