want to replace lifters
2001 stock FLHTCI (street legal pipes and stock EFI) 52,000 miles
I run both syn and dino and still hearing the ticking from rear rocker box. Have tightened every bolt and replaced exhaust gaskets. I run 93 octane gas.
Runs strong and smooth (no power loss) with ticking, especially at 3,000 rpm
Adjustable HD push rods, changed cam chain tensioner 12,000 miles ago.
I want to replace lifters. I've never done this--dealer did the push rods. How do you replace lifters and adjust the SE push rods?
Thanks.
1.) Take clip off pushrod tube, collapse tube and wire up outta your way.
2.) Unadjust pushrod and remove.
3.) Take 4 allens out that hold lifter cover down and remove cover.
4.) Pull out lifter. Replace lifter...Take not of anti-rotation pin. You'll see it and know what it is.
5.) Put lifter cover back on, preferably with new gasket.
6.) Put pushrod back in and adjust according to instructions.
7.) Put pushrod tube clip back on.
Use a combination of these three links to guide you through. Two show cam changes, but just worry about the lifter and pushrod portions.
https://www.hdforums.com.au/Default....ics&forumid=24
http://www.*****************/forums/tw...ain-noise.html
http://www.harleyhog.co.uk/camguidepage1.htm
FYI, that ticking is most likely going to be very hard to get rid of. But... I would check the adjustable pushrods IF the ticking started after their installation.
I, myself, have went WAY beyond all this to try to get rid of tick. HAHA But... with a 2001 bike, YOUR crank should be good to go. Most likely (if not a bad lifter) some end play on rocker arms. It will come down to what u can live with -vs- how much to spend to chase this down. I hope the lifters work, AND it IS something YOU can do!
Buy a service manual from your Harley Dealer, they are like $60. You really do NOT want to open up engine without one, even for easy stuff like this. Buy some blue locktite in a tube, too.
I own a POS bike. Right this month... I am going to install a welded trued and balanced crank, do a 106 kit, have my heads ported. In reality... this is because of damn tick. Its a well since I'm doin the crank( slipped crank, which YOU won't have)... might as well... thing.
Read this, too. http://harleytechtalk.net/htt/index.php?topic=7451.0
I have found, cause I lissent to Bob Woods and some others who really understand this, if you go a little further and target 0.150 down, things get much quiter.
For instance with 32 tpi pushrods that call for 3 turns down, go 4.5 turns down.
This with steel pushrods, which probably grow less that the cilenders as they get hot.
And this is just a pushrod adjustment. Not a replacement or any cost.
https://www.hdforums.com/forum/5305137-post115.html
...gene
Thanks for input. I have read several of your posts on this--you seem to know your stuff. I am going to adjust the pushrods first to make sure they didn't loosen up. Also, the dealer installed these but I want to adjust them myself. I'm getting to the point that I hate to pay for any maintenance and repair I can do myself. Besides, it makes you feel better about your bike when you've done a lot of the work yourself--you know it gets done right, not that the dealer doesn't care.
