Cam question
But here is something you may wish to investigate if you haven't already done so....
It's some of the components in your heads that may need attention.
Specifically the rocker arms, the rocker arm shafts, and some say the shaft supports.
Pull your rocker arm covers and check rocker arm side play with a feeler gauge. The more play... the more noise. This can be corrected pretty cheap with rocker arm shims used on shovels. Do NOT quote or use this, and please look in the SM, but I'm thinking anything over like .003 induces noise.
Also, you may wish to go further... check the diameter of the shafts for the rocker arms. They worn? Undersized in any way? Then look at the bushings inside the rocker arms. They worn? Oversized in any way?
If each piece is just a few thousandths of an inch the wrong way... combine the math from each piece and then you can see that there could be 8-10 thousandths of 'slop' right there. Everybody calls this added math equation 'valvetrain stack'. This is something that the lifters cannot smooth out... it can be like a moving target for the lifters.
I hope that this explains this good enough for you to see what I am trying to explain. I'm just a duma$$. But, if you like the Woods... there IS a reason that a few can be quiet, and others cannot. Also, if the stack and side play are outta whack.. buying new cams wont take out as much noise as you may think.
Crappy gas mileage is more of a PC III thing. A decent tune, NOT A CANNED MAP, can help that immensely.
