I just started a new motor, let it idle until the top of the rocker box's got warm and shut her down. While doing this i heard a tapping, is this a bad sign or just part of breaking in a new motor?
Tapping = problem somewhere. Could be clearance issue in the rocker boxes depending on your build or a lifter.
Ron
Stock cam or hi-lift? Could be what Ron indicated or something as simple as a pushrod out of adjustment if you do have adjustable pushrods. If it is a light tapping, I wouldn't be overly concerned but would try to identify it. If heavy, then cause for concern but still could be a lifter or pushrod.
