05 FLH Vibration
Old Aug 23, 2009 | 10:33 AM
terryjck's Avatar
terryjck
Stage IV
Default 05 FLH Vibration
Bike started to vibrate suddenly.cheaked frount motor mount,it was shot.replaced with new mount flatside up.no help cheaked alinement,hemi joints,and swingarm transmount. they were ok Decided to look into the cam chest.scoring on cam bushings,oilpump also.Decided to take bike into dealer,they replaced cams,lifters,and updated to new style billet cam plate.new oilpump I asked them to cheak crankshaft run out. it was .003 tech said crank had not shifted.They dyno tuned the bike with the SERT.Bike seams to run better,but vibration is still there not as bad,but not as smoth as it was.before all this **** happened.Tech said he thought it was not that bad,Hell ive been on this bike for 28000 miles,so i think i have a good feel for the bike,Hell i rode a buddies 117 evo last night,smooth as hell.he rode mine and said he would not ride that dam twin cam peice of ****OLD SCHOOL BIKER TRAMP) Im thinking its in the crankshaft.with all the problems im reading about this on these forems.Has anyone the same problem
Old Aug 23, 2009 | 11:17 AM
wurk_truk's Avatar
wurk_truk
Here's what you may want to check out before you move ahead.
Check the crank run-out on the output side as well. If the output side is also .003, you seem to be good. BUT... the two sides can have different run-outs.
Search around on these forums, they tell how to check this, OR have dealer check.
My crank DID twist... .0045 on cam side; .008 on output side. But I truly believe this crank runout thing is WAY over exaggerated by the internet and your vibration will turn out to be something else.
I have received the EXACT same treatment from HD dealer techs. It's MY bike, and I sure the hell knew exactly when the bike took a crap!
No warranty for me. The runout needs to be .012 for warranty, and THEN i just get another POS crank. No Thanks!
The bike is in 2.5 million pieces on the garage floor as we speak. Shipped the heads off Thursday, and will ship the cases out Tuesday. I am buying a VERY expensive crank ($1100)and having a Timken left side bearing installed. Also having ported; new cams; new size (106); etc since it is all apart anyway.
If I had to do it all over again??? I should have had my crank welded and trued, new rings and hone, and called it a day. But, NOW I WILL have a helluva bike, for sure.
13bob
Nov 25, 2014 02:34 PM
jim-d
Jun 30, 2009 08:17 AM
jn2jhavens
Sep 1, 2008 04:35 PM
harleywindrider
Aug 14, 2007 10:32 PM
Wacked
Jun 28, 2007 10:47 PM
