'02 twin cam tensioner upgrade
Old Sep 3, 2009 | 08:42 AM
wraplock's Avatar
wraplock
Default '02 twin cam tensioner upgrade
I sold my 70 shovelhead a few years ago and just got back up on the wheel. I Just bought this 2002 R-king and I'm starting to hear things said about upgrades to gear driven cams opposed to chain driven, Problems with cam chain tensioners And bad cam bearings. Can anyone shead some light on this for me. Do I need to do something under the cam cover for prolong life? The bike has 9000 miles, runs great, and is as quiet as a church mouse. Where might I find something to read up on this and what course of action is required. Thanks for your help.
Old Sep 3, 2009 | 09:42 AM
KumaRide's Avatar
KumaRide
Lots of discussions about this. Try searching "tensioners". Tensioners should be checked around 25-35k miles. No worries at 9k miles. Another option rather than gear drive is the hydraulic cam plate. Lots of discussions can be found about that new setup which is similar to what the 07+ softails have.
Cam bearings typically are not a problem unless you build the motor up. But, if you swap cams its recommended to upgrade them to Timken b-148's.
In short, check tensioners at around 30k miles and enjoy your bike!
Old Sep 3, 2009 | 10:20 AM
wraplock's Avatar
wraplock
Thanks man..Sounds like I have time before having to deal with this. Who knows, I may be riding something newer by then!
Old Oct 17, 2009 | 10:53 PM
harleymark's Avatar
harleymark
Well, if is anything, after 02, the crank bearing changed, for the worse. I've got an 03 dyna. Something I've looked Into, thinking of going gear driven cams, but crank run out could possibly be a factor, won't know till I get I there and check it.
pat_in_the_hat
Feb 18, 2019 09:47 PM
Stopit
Engine Mechanical Topics
Jan 25, 2014 02:36 AM
mebe007
36
Feb 19, 2009 08:46 AM
bruggy
106
Mar 20, 2008 07:58 AM
Timex
Apr 12, 2006 08:16 PM
