Cam Gears
Old Apr 2, 2006 | 08:47 PM
Timex's Avatar
Timex
Default Cam Gears
What's the deal with worn cam chains on the 88's?, and at about how many miles should I start watching for wear. I'll go to a geared system at that point if need be.
Old Apr 2, 2006 | 10:11 PM
spartns's Avatar
spartns
Default RE: Cam Gears
You'll get all sorts of answers here. I had the same concern. I just checked mine at 19,000 miles, looks like new. No wear. My dealer says that he's only had to change out 2 cam tensioners in 17 years. I don't know if that's true or not. Just check them every 15,000 and you should be OK.
Old Apr 2, 2006 | 11:53 PM
RBJones's Avatar
RBJones
From what I've read, the cam chain tensioner issue depends on how much you've modded. It seem to be a problem with radical high-lift cams and the required high-strength valve springs required to close the valves at high rpm. This stresses the cams rotation, hence the tensioners get increased wear. Probably reduces life expectancy of the cam bearings as well. Don Peterson has done a few columns on it for American Iron. If you're running stock or mild cams you probably are OK.
I've been trying to find someone with a stock 88 who has personal experience with tensioner failure, but nobody has responded so far.
Old Apr 3, 2006 | 04:44 PM
Y2K's Avatar
Y2K
ORIGINAL: RBJones
My friends '03 Ultra had the failure at 23,000 miles,completly stock bike.
My 2000 had the originals replaced with cam bearings at 40K when I had a 95" kit installed and they still looked fine.
Those just came out after another 65K ( I'm at 105,000 miles now) the front one looks ok but the rear one was toast.
I'm now Running gear drive cams.
Old Apr 3, 2006 | 06:17 PM
RBJones's Avatar
RBJones
I guess I can infer a couple of things from that: tensioner failure looks like a random thing on stock bikes, so I'm just not going to worry about it for now, and, if I do a mod, I'll install the gear cams as part of the process. Thanks for the info.
Old Apr 3, 2006 | 06:41 PM
liltrk's Avatar
liltrk
Three of us here...all stock with about 25,000 miles or so. All bad enough to change, one worn right into the metal.
Gear drive times three.
Old Apr 3, 2006 | 07:04 PM
RBJones's Avatar
RBJones
ORIGINAL: liltrk
liltrk,
Please tell me Harley fixed them for you at no cost.
Old Apr 3, 2006 | 07:13 PM
Cryptoboy's Avatar
Cryptoboy
Why would HD replace them at no cost, unless it was lin the standard warranty timeframe?
ORIGINAL: RBJones
ORIGINAL: liltrk
liltrk,
Old Apr 3, 2006 | 07:18 PM
CHIZ53's Avatar
CHIZ53
I started another post here on the same subject. I have 40K on a 2000 Rk. Going in today for a look see. My dealer said the worst they have seen had over 55K and were still OK. I'll let you know for sure in a couple of days.
If you HD motor is noisy, you need louder pipes...
Chiz
Old Apr 3, 2006 | 07:45 PM
RBJones's Avatar
RBJones
I was presuming they were still under warranty. If not, I guess you're hosed unless you have an extended.
