Fuel gauge problem.
Old Nov 23, 2009 | 02:27 PM
Skyglide's Avatar
Skyglide
2nd Gear
Default Fuel gauge problem.
Hello all, I have an 07 FXDWG. About a month ago for no apparent reason, my gas gauge became very unreliable (even more than normal). I can normally get about 180 miles or so out of a tank, and at about 90 it reads empty and starts flashing the last red LED at me. Was wondering if anyone knew what would cause this and how easy of a fix it might be? If its a huge task I will probably just live with it, but if its something relatively simple Id like to take a crack at it. Thanks for the help!
Old Nov 23, 2009 | 03:33 PM
stevelonewolf's Avatar
stevelonewolf
Is it reading the fuel incorrectly? (example)It reads empty and you have a half tank? check your fuel pump/sending unit connections under the gauge and in the tank. Sometimes the arm can get stuck as well.
Old Nov 23, 2009 | 10:18 PM
Skyglide's Avatar
Skyglide
2nd Gear
Yes it is reading incorrectly. It goes from full to empty in half a tank. Then the last half of the tank it just blinks that last red LED at me. I unscrewed the gauge and looked at the electronics and wires underneath, everything seems to be connected fine. I cant get too deep though, when i pull the whole gauge out of the bike the wires are really tight so I cant really get to far underneath it. What arm are you talking about that gets stuck?
Old Nov 23, 2009 | 10:43 PM
stevelonewolf
You have an arm inside the tank that has a float on it to rise up and down to the level of the gas. It's connected to a switch that makes contact sliding up and down as the gas level changes.
eskimo09
Jun 19, 2017 05:28 PM
RidemyEVO
EVO
17
Jun 4, 2014 01:08 PM
WVICEMAN
EVO
Jan 16, 2013 03:13 PM
BungoBill
EVO
Jul 23, 2010 02:48 PM
jfm5
Jan 27, 2009 08:40 AM
