power gains with SE heavy breather?
Old Dec 7, 2009 | 06:17 PM
toastman's Avatar
toastman
Default power gains with SE heavy breather?
i'm gonna be installing a SE heavy breather over this winter.
i havent done any engine mods, just changed the stock exhaust to samson big guns 3 street sweepers.
what can i expect to get out of my heavy breather? am i going to see power gains? sound improvements? neither? both?
a corollary to the first question: should i get the bike dyno tuned now that i've changed out the exhaust and intake systems?
i'm a master of the bolt on, but i'm rather green when it comes to anything having to do with my motor.
any help would be greatly appreciated.
Old Dec 7, 2009 | 09:24 PM
toastman's Avatar
toastman
nothin on this?
Old Dec 8, 2009 | 06:33 AM
FLSTF's Avatar
FLSTF
You will need some type of fuel management system (TTS, PCV, SEST, etc) if you don't already have one or you will be too lean. I'm sure others will chime in and better explain or be more specific.
Old Dec 8, 2009 | 06:58 AM
beaureed445's Avatar
beaureed445
The Heavy Breather is $300 worth of "looks cool." It probably won't flow any better than a typical Stage I K&N filter system. Ok, maybe just a little, because it's forward facing. I run one, and like it. As FLSTF mentioned, if you haven't done so, you should consider adding some sort of fuel management system, and having it tuned by a professional.
Old Dec 8, 2009 | 08:03 AM
rbabos's Avatar
rbabos
Many have found hp increases and leaner running using this breather. It does flow better than the regular SE units. Tow reports that come to mind if I remember correctly were a need for fuel adjustment from Shovelhead Bob and actual testing of various breathers from a tuner overseas on a HQ build. I think he gained about 5-8 compared to the regular SE breather.
If I'm incorrect on this Shovelhead, I appologize for the misinformation. Memory's not 100%
I'd also like to point out that modifying this breather to vent externally would be a good idea to reduce carbon in the engine. On teardown using this breather, I had an insane amount in the head and piston tops. Seeing that, I've since vented to ground.
Ron
Old Dec 8, 2009 | 08:33 AM
beaureed445
Ron
That makes 2 of us. I'm seriously debating re-installing this on my 113" build, or switching to something else. Ron, I'd like to see pictures of your external venting invention, if possible. Any ideas would be helpful at this point. Thanks.
Old Dec 8, 2009 | 09:27 AM
meatball64's Avatar
meatball64
+2 on the external venting.
Old Dec 8, 2009 | 02:03 PM
hommes's Avatar
hommes
Default Heavy breather...
That heavy breather might breath heavy ( like suck the money right out of your wallet ) but doesn't seem to add much in terms of HP. I found some info last week about a guy that put a heavy breather on a new stock honda fury and then did a dyno test to get the HP increase. It recorded a 1 HP increase. OK, it was on a Honda. I know. It didn't have after market pipes or fuel management either...But still...
I wonder how much HP it would have added to a stock Harley?
Old Dec 8, 2009 | 02:15 PM
toastman's Avatar
toastman
thanks guys for all your input.
my gut told me that i'd probably have to install the power commander and get it tuned, and you guys backed that up for me.
i'm doing a ton of cosmetic mods to the bike right now so cash is short, but what i think i'll do is install everything i was planning on installing, let the bike sit and look pretty stored up for winter, then right before the season starts up again pony up the cash for a power commander and get it tuned up.
bottom line though: with the breather, aftermarket pipes, BCT baffles, PCV and a dyno tune from a tuner who knows what he's doing...should i expect gains?
i'm not looking to ride a missile otherwise i'd have just rebuilt my engine with all this money. just wondering whether or not my aesthetic mods are gonna do anything for me other than looking good.
Old Dec 8, 2009 | 02:34 PM
meatball64's Avatar
meatball64
Yes if you dyno tune you will see a gain in HP. How much I can't say but it will be more than one HP I'm sure. however I would be concerned about the carbon build if in fact the heavy breather is the cause.
