Compression Releases
Old Jan 3, 2010 | 02:03 PM
customsoftail200's Avatar
customsoftail200
Default Compression Releases
I'm doing a 95 build on my Twin Cam, it will have approx. 10:1 compression, and Andrews 54 cams with ported and polished heads. Are compression releases going to be necessary??
Old Jan 3, 2010 | 02:07 PM
jimsflh's Avatar
jimsflh
Cant hurt, and will definately save you money on starters!
Old Jan 3, 2010 | 02:34 PM
maineultraclassic's Avatar
maineultraclassic
It's always a good idea to have them installed when the heads are off, even if you don't think you'll need them..........do it now. Much easier then finding out later that you do need them, and having to tear the motor apart again to have them installed.
Steve
Old Jan 3, 2010 | 03:08 PM
thedonthere's Avatar
thedonthere
Don't even think about not doing it. Saves on starters and batterys.
Old Jan 3, 2010 | 03:11 PM
wurk_truk's Avatar
wurk_truk
I would say that you will not 'need' them. But.... how much would it be worth for that one hot day, after buying gas with a bunch of friends, and the bike won't start properly?
I would think that $100 now is just too good of a deal to pass up, compared to any trouble later. Have the head porter put them in, like Big Boyz did for me.
And... here is the thought... you may not keep those 54s in there forever and the 'new' cam could really use the releases... but you were too cheap to do it way back when.
Old Jan 3, 2010 | 03:14 PM
prodrag1320's Avatar
prodrag1320
put them in for sure,even if their not a nessecity,they will be a whole lot easier on starting system
kirby
facebook: kirby apathy
Old Jan 3, 2010 | 03:17 PM
BoomerBob's Avatar
BoomerBob
Yep. You'll need them when you stop for gas and try to start it again and get the dreaded compression lock. Don't ask me how I know.
Hot starts can be very hard on the starter with a higher compression motor. Some people just get more powerful starter then break the jack shaft which could also damage other parts in the primary.
Old Jan 4, 2010 | 09:52 AM
Old Gunny's Avatar
Old Gunny
Couple of things about hot starts.
One came from a suggestion on this site from somebody and this works.
When you start your auto you just turn the switch don't you? You don't wait for it to go thru its pump up routine do you? May not hear it but it does exactly the same, all the same.
Do that with the Harley. Turn the switches and hid the start button right away. Easy start up. Check Engine comes on, but then goes away a few seconds later.
Another for high compression, high lift engins is S&S travel limiters for stock type lifters.
Doesn't let the lifters bleed down far when stopped. Especially troublemsome when hot.
If stock lifters are adjusted stock you can loose 0.100 in. lift at hot start.
Old Jan 4, 2010 | 02:28 PM
sniper77's Avatar
sniper77
I'm running a 95" with 10.1:1 comp and Andrews 54H cams.
I use the rear comp release religiously, it really helps.
I noted and then was confirmed by my machinist that these fuel injected bikes don't like the front comp release. If I use both front and rear it doesn't start as quickly. The rear cylinder is typically the one causing any problems needing the release.
Good luck and enjoy.
Old Jan 4, 2010 | 03:37 PM
customsoftail200
Mine is carbed... I think I'm gonna bring the heads to the machine shop and get 'em done..
