Looking for cheap power?
Old Jan 15, 2010 | 10:03 PM
producer's Avatar
producer
Originally Posted by txtec
the ones everybodys selling is the take offs or recalls from cvo 110 bikes,i dont know if there the same 110 heads in the s.e. catalog. usually go for 250 to 275 dollars a set. there was a set in the classifieds here for 275.
Ah, ok
Old Jan 15, 2010 | 10:19 PM
txtec's Avatar
txtec
the 110 heads are still in the classifieds for 275,if the make 92 hp in a 88 with 7to1 compression. maybe i should buy them for my 95 with 10.8 compression ,it oughta make 125hp. i wished. lmfao
Old Jan 15, 2010 | 10:27 PM
producer's Avatar
producer
Correct and also LMAO
Old Jan 15, 2010 | 10:32 PM
producer's Avatar
producer
Heay MLWILSON,
We are waiting patiently for this physics/engineering project to be explained. Thanks a head of time.
Old Jan 16, 2010 | 06:45 AM
MLWilson's Avatar
MLWilson
Responding to you two clowns is a waste of my time.
Old Jan 16, 2010 | 08:28 AM
prodrag1320's Avatar
prodrag1320
care to post the dyno sheet??? 91hp out of a 88 with less than 8to1 compression is pretty hard to believe. how did you keep those 2.08 intake valves from hitting the pistons that are cut for 1.85 valves???
with the TDC lift of the SE.251,the valves wouldnt be coming near the pistons at TDC,so piston clearance wouldnt be a prob
Old Jan 16, 2010 | 09:05 AM
txtec's Avatar
txtec
Old Jan 16, 2010 | 09:13 AM
Faast Ed's Avatar
Faast Ed
harley recalled alot of 110 heads and didnt ask for them to turned in is why there so many for sale so cheap.
didnt ask for them to turned in ?????? I find that one a lil hard to swallow.
Old Jan 16, 2010 | 09:24 AM
txtec's Avatar
txtec
ask your local dealer tech would be a easy way to find out. why are there so many for sale cheap??????
Old Jan 16, 2010 | 09:25 AM
rob71458's Avatar
rob71458
If those numbers are true, which I really doubt, then it probably hits them at a high rpm for a brief moment. This thing must be a pig below 4K rpm. On another note. These heads do perform well on large engines, like 117 and up.
