Valve bent?
Old Jan 24, 2010 | 06:15 AM
ricksterzz's Avatar
ricksterzz
Stage IV
Default Valve bent?
Could this have bent a valve? I was getting ready to change out my rocker boxes on my 2004 FLHT when I had this problem. I had my spark plugs out and was finding TDC with the pencil method watching it rise. This is the real dumb part.....I didn't realize that a part of the pencil broke off and I continued to turn the rear wheel and now I have a bigger project. I took the head off and found the part of the pencil that broke off flat as could be and I mean real flat. I could see where the valve had press it down,but it looks fine. How would I know for sure if is damaged in any way. I will never check TDC this way again...I will learn from this mistake.
Old Jan 24, 2010 | 08:34 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
With the head off, put some fluid in the port of the suspected valve problem.
If it leaks into the chamber, they it is time to address it.
Scott
Old Jan 24, 2010 | 09:08 AM
SLPER's Avatar
SLPER
Default Bent Valve
Hey,
If it takes some pressure to push the valve stem back thru the guide would that be a bent valve?
Cheers!
Old Jan 24, 2010 | 09:14 AM
Faast Ed's Avatar
Faast Ed
Use a McDonald's drinking straw next time,......
Where'd you get that pencil idea? Ouch!
Old Jan 24, 2010 | 11:34 AM
ricksterzz's Avatar
ricksterzz
Stage IV
Thanks guys...I had no fluid leakage at all.
I read it another forum....Straw or finger next time.
thereal142
Jun 27, 2012 09:06 AM
1989 fxr
Shovelhead
14
May 15, 2012 07:36 AM
dan61t
Apr 24, 2012 07:24 PM
harleylay
Feb 27, 2011 10:55 PM
Reffixer
Jan 10, 2006 01:22 PM
