I just replaced the cam tensioners on a 05 Road King. It starts hard and the front cylinder does fire and gets warm but is not a 100%. The rear is fine. Do you think this is cam timing or do I need to re-adjust the push rods? I checked them and they do spin at TDC. Thanks
Reason: spelling
Agree with Gunny. Just because the PRs spin when at TDC doesn't mean they are adjusted properly. Start over, make sure the piston is at TDC and on the compression stroke; then try again. If that doesn't solve the problem, pull the cam plate and check everything.
Agree with Gunny. Just because the PRs spin when at TDC doesn't mean they are adjusted properly. Start over, make sure the piston is at TDC and on the compression stroke; then try again. If that doesn't solve the problem, pull the cam plate and check everything. If all was OK before, it has to be something done in the tensioner R/R.
Ooops, sorry for the double post; my bad. I would delete if I could but I can't.
