fitting slip ons
Old Feb 28, 2010 | 06:57 AM
FD2's Avatar
FD2
Default fitting slip ons
I am stuck trying to fit a pair of rinehart slip ons to an 09 sporty. The rear goes on easy. The front stops about 1/4in short of the bolt mounts. I have checked that i have got the right mufflers for front and back and lubricated the pipes but no joy. Any ideas?
Thanks
Peter
Old Feb 28, 2010 | 08:02 AM
extech's Avatar
extech
The front and rear muffler should be identical, if not, the mounting boss is welded in the wrong position.
When the muffler "stops" is it bottoming out or hitting the heat shield? 2009 and newer Sportsters have a redesigned heatshield that is about .500" longer than the previous. If this is the issue, loosen the heatshield completely and try again. You'll probably have to reposition the shield once the muffler is installed, and it is possible that the shield will contact the muffler, eventually gouging the chrome.
Old Feb 28, 2010 | 09:13 AM
FD2's Avatar
FD2
Default muffler
Hi Extech,
its not the heat shield. Looking at it is seems that there is a 'step' in the down pipe extremely small but there doesn't appear to be any way I can get this muffler over it - the tolerances are too tight. The pipes are right for the bike and the year so ....it looks like I have to take the down pipe off an have it turned down a fraction for about a half inch. And when I say a fraction I am talking a finger nail thickness.
If it had been as easy as the back pipe I'd have been riding now and annoying the neighbours....
Pete
Old Feb 28, 2010 | 09:23 AM
ajayrk's Avatar
ajayrk
Check with a muffler shop and use their muffler expander.
http://www.mytoolstore.com/kd/kdspec03.html
Or have someone turn you a tapered driver and drive it into the inlet. Be sure the driver has an internal thread at its rear so you can pull it out.
Old Mar 1, 2010 | 04:00 PM
FD2's Avatar
FD2
Default mufflers
well I tried spreading the flange but with no joy. Then I tried swapping front to back and they both fit. The instructions say that they are specific assemblies but i can't see how they would be different - so - any reason why I shouldn't just tighten it all up and go ride?
Pete
Old Mar 1, 2010 | 04:34 PM
FD2's Avatar
FD2
Unhappy Idiot
Well I have the explanation. The mufflers sold to me as for an 09 actually are for 01 - 07.
I can't take them back. So, if they fit albeit the 'wrong' way round should I just run them? Is there a material difference between an 07 and an 09 run without the 02s. I will be adjusting the fueling.
Thanks
Peter
Old Mar 1, 2010 | 04:57 PM
exemexer's Avatar
exemexer
If you asked for a set for an '09 and they gave you '02 thru '07 or what ever you should be able to take them back.
Old Mar 2, 2010 | 12:31 AM
FD2's Avatar
FD2
Default mufflers
I am in Livepool Uk and bought the pipes from the US on ebay...
Old Mar 2, 2010 | 08:34 AM
ajayrk's Avatar
ajayrk
Your stock mufflers are probably catalytic mufflers and the mufflers you have now are not.
If they fit and they have the crossover and it fits they should work.
If the O2 sensor is in the head pipe and not the muffler the system should be able to adjust to the change in air flow.
If you add a free flowing air cleaner you will need a fuel management system to over come the lean condition.
Old Mar 2, 2010 | 12:25 PM
exemexer's Avatar
exemexer
Damn! Diabolical!
BMyers
Mar 11, 2012 03:07 PM
FD2
Mar 1, 2010 04:30 PM
ashenfang
Aug 12, 2008 11:07 PM
Domestic Violence
Mar 29, 2007 01:35 AM
WVICEMAN
Mar 15, 2006 11:30 AM
