Cycle Shack
and was wondering if anyone has the instructions. I want to make sure I don't damage the gaskets. Thanks
Before you take anything off, note where the clamps are oriented originally. You may want to alter the factory clamp location slightly, but generally speaking the factory position is about optimum. Be sure and clean the fingerprint oil off all chrome surfaces with Windex With Ammonia before starting up the first time. If you don't the stain can be permanent. Remembering back, I also removed the A/C Shield and air cleaner element just to prevent me from hitting the Shield with a wrench.
Be sure to box up and save your original mufflers. Someday soon we might be forced to put them back on to pass the EPA's inspection.
My CS Turnouts are a little loud, but are quiet enough if I am not hard on the throttle. You will enjoy them! Be sure and rejet your Carb as required. ................... BC
That was a world of good advice much appreciated. I've never on a bike but plenty of cars, just don't want to make any mistakes with my baby.
The dealer will have the exhaust gaskets in stock. They do muffler swaps all the time so little chance they won't have any on hand. They run about $8 for a set of SE gaskets or $5 (each) for stock ones. I have no idea why the stock ones cost more or what the improvement is on the SE set. I was real careful getting mine off and only had about 300 miles on them so I reused OEM gaskets. But $8 is an inexpensive piece of mind. You can always take them back if you don't need them.
Loosen clamps on heat shields - standard hose clamps. I think its 2 per pipe. The instructions will tell you to remove the heat shields. Your call. I don't think I really needed to.
Loosen clamp between muffler and exhaust pipe, one each. Slide it forward off the muffler and onto the exhaust pipe out of the way.
Remove 2 bolts under each muffler. These attach muffler to crossover tube.
At this point you should be able to wiggle the mufflers off.*** Look underneath the mufflers forward of those 2 bolts you took off. You'll see the quarter sized coupling where those gaskets are located. Careful not to smash them when pulling the mufflers free (if you plan to reuse them).
Install is pretty much in reverse.
***Some people said it was a bear to get the old mufflers off. Mine weren't too bad. I used a big bladed, flat tip screw driver and a hammer and carefully tapped on the edge of the muffler to break the seal. Then I held the screw driver in the expansion slot and twisted a bit to open it up. I also loosened the exhaust pipe mount bolt on the rear pipe. The exhaust pipe/head mounting has a little play in it to allow you to pull the mufflers off the crossover tube and then wiggle them off. Its slow and methodical. I took about 2-3 minutes (max) per muffler. I wiggled north, south, north, south, etc......then east, west, east, west.......while pulling toward the rear of the bike. It feels like nothing is happening at first but then you'll see them slowly start to come off.
I read some stories about difficulty getting the old ones off; some said over 2 hours of banging and pulling. But the whole install took me MAYBE 30 minutes start to finish. And that includes the time it took me to polish and box up the old mufflers.
Oh yeah, make sure you pull out the crumpled newspaper from inside the pipes before firing up your ride. I didnât see it right away.
This is an easy install. Instructions with the mufflers and this will be more than enough to get it done. It'll all make sense once you're hands-on. If you need it, the service manual also describes muffler removal on pages 2-104 to 2-106.
Good luck. Don't forget the last step....post pics and let us know how they sound.
EDIT: Didn't see Big Cholla's post. Unlike him, I didn't pull the header pipes off. Like I said, I only had about 300 miles on the bike so I wasn't too concerned about internal engine problems. Figured it was too new to tell anything anyway.
6700+ miles on the CS slipons and I still love 'em.
Good luck!
What a GREAT bunch of Enthuisust's!
