twin cam fouling spark plugs
Old Mar 7, 2010 | 08:25 AM
s.ga.rider's Avatar
s.ga.rider
Default twin cam fouling spark plugs
My 03 softail keeps fouling the plugs in cold weather. The carbs have been checked at the dealer, new plugs, and the intake manifold gaskets replaced(no difference) but when it is below freezing outside after 10-15 miles it will start missing. Up to that point it runs perfect but it will skip like its not getting spark and running on 1 cylinder. It runs really rich at that point of course puffing black smoke at idle. In the warm weather it runs perfect. The dealer suggested possibly a crack in the crankshaft position sensor but said they couldnt tell for sure till it was acting up. Left it with them over night and they put 2 miles on it and said it run fine. I am at a loss. Any suggestions before I order a cps?
Old Mar 7, 2010 | 01:17 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If injected, the cold start mode, needs attention.
Scott
Old Mar 7, 2010 | 04:49 PM
Crazy Canuck's Avatar
Crazy Canuck
Just curious. You say the carbs have been checked. Do you have a 2 carb set up?
Also. When below freezing. What is your start up proceedure. Ex; full choke, 1 twist of the throttle etc...
Old Mar 7, 2010 | 06:28 PM
s.ga.rider's Avatar
s.ga.rider
I have 1 carb and I have no issues at start up. It only starts acting up after 10-15 miles. Runs perfect till then but I do pull the enricher to let it warm a few minutes before riding.
Old Mar 8, 2010 | 05:31 AM
Hillsidecycle.com
Sponsor
My mistake, as I read the post too quickly, and had not noticed that you were carb equipped.
Sounds like a plug partially fouling, and then clearing out.
What pilot jet are you using??
Scott
Old Mar 8, 2010 | 08:13 AM
s.ga.rider's Avatar
s.ga.rider
I dont remember right off. The dealer checked the jets and adjustments on the carb and said it was fine. I rode it to work yesterday morning below freezing and it fouled the plugs after about 20 miles, I cleaned them and rode it this morning at around 38 degrees and it ran perfect.
Old Mar 8, 2010 | 08:18 AM
Hillsidecycle.com
Sponsor
If in fact it is a dry soot, then the carb needs to have the jetting backed down.
Scott
Old Mar 8, 2010 | 02:27 PM
qtrracer's Avatar
qtrracer
Does your bike have a temp controlled warm up enhancement , I think I remember my last stock carbed(and stock a/c) bike having a temp controlled flap that would speed up the warm up process, if the temp dropped below a set temp, by pulling in air that is next to the cylinder thru a little window about the size of a stamp. If you have this setup maybe the flap is sticking in the warm up position and not opening even when it supposed to. I don't know if this would choke off some of the airflow or not. But it does sound like a temperature based problem. Been so long since I've seen a stock a/c I can't remember much about them.
Old Jun 13, 2012 | 03:03 PM
tom crow's Avatar
tom crow
Stage I
Default fuel injection fouling plugs
what if its a fuel injection fouling the plugs runs like its on one cly. front cly. gets fire. but does not get hot just warm rear gets hot . can you give me ideal whats up
catsmtrods
Carburetor Related
14
Feb 3, 2020 03:14 PM
Bill C
Jun 3, 2011 09:28 AM
parts eeter
Jan 30, 2011 01:11 PM
mucklepilly
Apr 9, 2010 08:54 AM
badbs101
Nov 15, 2009 02:23 PM
