Pushrod tube question
Old Mar 10, 2010 | 06:05 PM
Mike0469's Avatar
Mike0469
Stage II
Default Pushrod tube question
I am installing SE quick install adjustables and have a question about the pushrod tube clips. When I install the clips, are the spring collars supposed to overlap the bottom of the clip? I can grab the bottom of the clip with my fingers and pull it out without depressing the collar. Is this normal?
Old Mar 10, 2010 | 06:27 PM
Kingofcubes's Avatar
Kingofcubes
If by clip you mean keepers no, you don't have enough spring tension to keep the covers from leaking. Longer keepers would be in order. Are you sure you have all the parts installed?
Old Mar 10, 2010 | 06:33 PM
prodrag1320's Avatar
prodrag1320
unles you have a TALL,big inch motor,your doing something wrong
Old Mar 11, 2010 | 11:47 AM
djl's Avatar
djl
No. Those pushrods normally come with tubes, clips and o-rings; sounds like you have the wrong parts.
lmz5150
Shovelhead
29
Apr 15, 2019 05:18 PM
AFDynaRider
Aug 20, 2018 07:57 AM
brogers
Jan 9, 2011 12:41 PM
EC145Pilot
Apr 27, 2007 09:41 PM
Greg
Jul 16, 2006 08:44 PM
