VROD Cylinder compression question
Old Mar 20, 2010 | 03:16 AM
Harlen Vega's Avatar
Harlen Vega
Default VROD Cylinder compression question
Im popping my forum cherry on this one so I hope it hasn't been covered in 40 pages of data I entirely overlooked.
Heres my question:
Why is the rear cylinder compression so much higher then the front cylinder on the Vrod. Off the top of my head I believe its a difference of around 80-100psi. Front cylinder is approximately 113-135 and 205-245 for the rear. Again the specs are from memory and accuracy of the spec in this regard is not vital to me. The reason (if any) for the difference in compression, which I feel is pretty substantial between the two is the focus.
As a side note, It would seem to me that the higher compression cylinder should be in the front since it will create more heat than the lower compression cylinder regardless of the fact that this is a liquid cooled machine. Am I off my rocker on this one? Im hoping for an explanation of some engineering brilliance to align myself with here.
I look forward to finding out more of what this is all about.
Old Mar 20, 2010 | 08:38 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I believe those have spring loaded compression release lobes on the heel of the cam at where it would normally be closed.
As the rpms increase the release is retracted via centrifigal force.
Scott
Old Mar 20, 2010 | 06:04 PM
Harlen Vega
Scott
The ACR or automatic compression release was available on models from 2002-2007 if memory serves me right. I'm not too sure they have a spring load however. I'm fairly certain they are counter balanced and swing freely when no force is being applied. You are correct they do work off of centrifugal force.
I will rephrase my question.
Was the compression intentionally made higher in the rear cylinder... and why? What mechanical benefits does this attribute to if in fact it was intentionally engineered that way.
There's also the possibility I may be simply asking the wrong question as well.
Old Mar 21, 2010 | 07:43 AM
Hillsidecycle.com
Sponsor
What I was getting at was that the releases could be causing that varience.
Was anaware of the later models not having them.
Certainly sounds odd that both are not carring the same ccp.
Scott
Old Mar 21, 2010 | 02:34 PM
Harlen Vega
Ah I see what your saying. Ill have to tear one down on Monday and take a closer look at what is going on there. I talked to a vrod instructor friend of mine and he said the question for some reason has never crossed his mind and admitted that he was a little confused on why he had never thought of it. Him and I are going to take a closer look into this on monday when we can get a motor in front of us.
Old Mar 21, 2010 | 05:42 PM
Hillsidecycle.com
Sponsor
Keep us posted on your findings if you would.
Scott
Old Mar 21, 2010 | 10:04 PM
06roadglide's Avatar
06roadglide
I remember when the V-rod was released I seen a cut-away of the engine and I put my finger on a part in the front head and asked the rep. what it was, sure enough, it was a cintrifugal compression release on the cam. I don't recall seeing it on the rear so that may be why I asked.
Old Mar 22, 2010 | 12:51 PM
Harlen Vega
Scott
Sure thing. Hopefully Ill have some more difinitive answers this evening. Ill let you guys know.
BobRR
Apr 8, 2019 12:44 PM
run1fsr
Shovelhead
Aug 13, 2014 06:41 PM
tomlescal
Feb 21, 2014 12:01 PM
verybadmonkey
Apr 15, 2010 07:57 AM
wallyn
May 16, 2008 05:47 PM
