Cam Synch/Timing
Old Apr 27, 2010 | 04:49 PM
Trippie's Avatar
Trippie
Default Cam Synch/Timing
How would one tell if their cams are not lined up dot to dot, short of pulling the cover? What would be the performance characteristics of such a problem be?
thanks guys!
Old Apr 27, 2010 | 05:18 PM
Blk and Chrome's Avatar
Blk and Chrome
Even if you pull the cover you still can't see the cams. To check if the cams are in right is a time comsuming project. Too much to go thru here.
Old Apr 27, 2010 | 05:31 PM
thedonthere's Avatar
thedonthere
it would run so bad that you would know it right away.1 tooth off f*$%s **** up
Old Apr 27, 2010 | 06:30 PM
xxxflhrci's Avatar
xxxflhrci
All he needs to do is pull the cover to see the timing marks on the gears.
Attached Thumbnails Cam Synch/Timing-limited8.jpg
Old Apr 27, 2010 | 06:35 PM
Old Gunny's Avatar
Old Gunny
As long as the individual cams dots that are behine the support plate are lined up.
Old Apr 27, 2010 | 07:33 PM
Blk and Chrome
I took it as the ones behind the cover. Maybe I read it wrong either way it would run like crap.
Old Apr 28, 2010 | 08:36 AM
Old Gunny's Avatar
Old Gunny
Your right and your right.
sixshooter
Jan 20, 2010 10:06 AM
sixshooter
Dec 30, 2009 03:51 PM
redbull
Ironhead
17
May 24, 2008 01:19 PM
jcarson
Ironhead
Jun 23, 2007 12:27 PM
