Ironhead A place to talk about Ironheads.
cam cover ???
Old Jun 23, 2007 | 04:39 AM
jcarson's Avatar
jcarson
Default cam cover ???
i had a good oil leak inthe cam cover gasket,so i bought a nw gasket and decided to to dry it up.,,,but when i pulled off the cover the 2 rear cams fell ,,perfect [:@]so i took out the push rods and brought the cams bak into time but what about that silly breather valve? i dont have any idea about it. since it was the back cams that came out. i shouldnt have to retime it right??ive delt with lots of old shovels but they dindt have ALLL THOSE DAMN GEARS AND CAMS .... its maddninig thanks,,jared
Old Jun 23, 2007 | 08:59 AM
piniongear's Avatar
piniongear
Default RE: cam cover ???
As long as the oil pump breather gear has stayed engaged with the piniongear, the breather timing will remain unchanged. You should be good with that.
Another concern is to make double sure that you still have the thin spacings washers on each cam. These set the end clearance on the cams (side to side) and are either .005 or .007 thick. There will be a combination of these with the cams. Also, be sure that the cam backplate for the cams is in place before you install the cams back in. Be sure that all of the cam timing marks are correctly positioned.
After that, I will assume you know the proper drill for setting the tappet clearance. If not, let us know so that you can do this correctly...........pg
Old Jun 23, 2007 | 12:27 PM
jcarson's Avatar
jcarson
yea i know the drill for the tappets, i watched out for the came shims. the film of oil held them on.i have a manual so i was just checking.its not to clear on some things, thanks alot pg,,,,jared
klaybus
Exhaust System Topics
Jan 8, 2012 10:03 AM
Trippie
Apr 28, 2010 08:36 AM
redbull
Ironhead
17
May 24, 2008 01:19 PM
Satch
Ironhead
Apr 15, 2008 02:02 PM
