Oil filler cap blown out...
I drive a 2001 Roadking, which is heavily modified.
The engine is a custom build 124 with Harley, S&S parts and R&R parts:
Stock Harley Davidson case
S&S 106-0183 124" hot setup super sidewinder kit
S&S 640 Gear drive cams and S&S gears
R&R 17-1001 stage V twin cam cast cylinder heads
PSI Series 4 production GENESIS "BIG-AIR" carb
Feuling cam plate
Feuling super pump
Feuling lifters
TP 254-20TC Pro vent rocker boxes
TP 45-0245-23 Roller rockers
Engine custom built by R&R cycles (Manchester NH)
It puts out >140HP and >150 lb/ft.
I have an oil pressure gauge attached and it always shows a pressure between 50 (idle) and 70 psi (full throttle).
Because I changed the starter for a heavier model I fitted an oil filler spacer kit.
Now for my question. When I ride it hard I have lost my oil filler cap twice now. Its a mess!!
Almost a quart oil comes out at full speed on the highway.
Internal pressure blows it out I guess but what could cause this pressure. Should I be worried??
I can fix it, by securing the filler cap with a screw, but I need to know what causes it.
Thanks very much for any answer you can give me.
Regards,
Michael.
* I changed the oil and checked it for metal: nothing there
* I tested compression: cold engine, full throttle give 190 PSI on both cylinders
* My oilfilter is one from K&P Engineering, the oil is redline 20w50
* I fill the case up with 4 quarters
* The build is new and has run for around 1000 miles.
I'm thinking of use this device: http://feulingparts.com/wp/feuling/v...breather-kits/
Any advice or comment would be very nice.
Thanks all and ride safe, but hard :-)
http://www.badongo.com/nl/pic/9481096
http://www.badongo.com/nl/pic/9481093
http://www.badongo.com/nl/pic/9481091
http://www.badongo.com/nl/pic/9481089
http://www.badongo.com/nl/pic/9481078
If have changed oil and filters. Not much debris in the oil... Made the pressure release on the oil filler as you can see in the pictures. Put in 3.5 quart oil and now I ready to ride... I hope.
Next weekend is a run/rally and I hope to put on 1000 miles. I hope everything goes well. I have decide to ride on and check the engine in wintertime. We only have 6 month of reasonable weather and I want to make the most of it :-)
Many thanks for all information and comments.
Please answer one last question:
I have a mechanical pressure gauge, but I think it's not functioning ok.
I have found a readable and semi-affordable digital gauge to use for oil pressure and oil temperature at the same time (I have been looking for that):
http://www.spatechnique.com/product_...page.cfm?cat=2
I know where to put the pressure sensor.
But what is a good spot for the temperature sensor?
I see a plug in the oil reservoir (under the bike) just above the oilplug.
Is this usable? What tread size? The sensor has 1/8npt thread and is about an inch long.
Any comment is welcome.
Feuling cam plate
Feuling super pump
Feuling lifters
Regards,
Michael.[/QUOTE]
