Near catastrophe
Old May 27, 2010 | 12:51 PM
Bill C's Avatar
Bill C
Default Near catastrophe
I’ve had adjustable Screamin Eagle pushrods on by bagger for several years and have installed/adjusted several times with no issues (cams, tension shoes, lifter replacement, etc). Several days ago I had to remove/install and thought no big deal. Well, I went out for a ride and all of a sudden heard a bunch of noise. Limped back home on one cylinder (fortunately I was close to home).
Lifted the push rod cover tube and the bottom part of the pushrod was gone. I thought WTF and looked closer. The locking nut had come completely off and the bottom of the pushrod had screwed itself into the upper part of the pushrod. No locking nut to be found. I had a real sick feeling in my stomach because I knew the lock nuts were tightened when I reinstalled.
Anyway, took the cam cover off and there it was in the bottom of the cam chest. I looked at everything expecting to see shards of metal all over the place, but found nothing. I reinstalled the pushrod this time using Permatex Red thread locker. Motor runs fine like nothing happened.
Old May 27, 2010 | 01:37 PM
paul s's Avatar
paul s
I'm glad I don't have adjustables. I've seen too many threads like this one.
Old May 27, 2010 | 01:42 PM
xxxflhrci's Avatar
xxxflhrci
I had an adjustable loosen up after being in a couple of thousand miles. I put blue locktite on them and haven't had any trouble in 5 years.
Old May 27, 2010 | 01:51 PM
oldbiker771's Avatar
oldbiker771
They make a thin green loktite that can be put on after youre done adjusting and tightening, it seeps into the threads. More convenient.
Old May 27, 2010 | 06:03 PM
Old Gunny's Avatar
Old Gunny
Some say red but I did that once. There is red and then there is RED.
Old May 27, 2010 | 06:20 PM
mentor70's Avatar
mentor70
had that happen to my with my S$S adjustables, right after my cam install.
went down the street and after a few blocks my **** was running on 1 lung!
i carefully puttered home and fixed it. Def need to double ck that adjustment when the cam install is done!
Old May 28, 2010 | 02:11 PM
prodrag1320's Avatar
prodrag1320
never used loctite,never had them come loose,if properly tightened they wont
Old May 28, 2010 | 02:23 PM
paul s's Avatar
paul s
Kirby, do you use them in that drag bike?
Old May 28, 2010 | 04:05 PM
wurk_truk's Avatar
wurk_truk
My Smith Bros EZ pushrods came with a tube of red. I used red on top and bottom locknuts.... then changed lifters.. What a PIA!!!
So, now I use red on the bottom locknut and simply tighten the top, just like the SEs before. Works good enough for me.
Old May 28, 2010 | 06:44 PM
prodrag1320
we use adjustable tappets.ran adjustable p/rods in most our gas bikes(biggest 167" with a .990 lift cam,still never had one come loose)the only way i would ever run solid p/rods in a performance motor,is to get a set of adjustables,put them in,adjust them,take them out(marking each position)and get some smith bro`s blanks and make them to the exact measurment of each p/rod.
crazytown
Engine Mechanical Topics
22
Apr 18, 2016 11:41 AM
18BKLR
Nov 13, 2010 04:12 PM
0734
45
Sep 14, 2010 04:26 PM
2wheeltom77
18
Mar 14, 2010 11:43 AM
sniper77
Nov 29, 2009 05:23 AM
