BIG Build?!
It is inevitable that a truly big engine will give big performance, but what I have in mind is a big lazy engine, rather than a drag-strip queen, for my bagger. I am thinking of a monster motor without too much monster performance.
Why? Because it takes my fancy!
I have recently come across the Ultima 140 and S&S 145, which are cheaper (its all relative!) than the billet motors. So rather than the dragon-slaying HP some of these promise, is it feasible to detune either of them to around say 1 HP/TQ per cubic inch, with a wide easy torque curve and a forgiving nature?
Or is that a dream too far and those monsters cannot be tamed or made to change their ways?!
Someone would have to get the pressure bled off without a loss of ride-ablity, and giving it a radical lumpy idle at the same time. interesting topic
The Ultima has 10.8:1CR and the S&S 11.1:1, which is serious stuff.
What I have discovered is that S&S makes four versions of their V124; stock, EPA, CARB and TuV (German Government). The stock version is 10.8:1CR, but the TuV has 9.5:1CR, same as my S&S V107T. So around 9.5:1CR and a 'gentle' cam might do it!
Then there is the drive-train to beef up, frame to cut about....
Your thoughts on "detuning" is actually practical only if all components are designed for the detuning. For example, just putting a lower lift, less duration cam will most likely push the CCP higher and could create tuning issues. If you could get one of these engines built with matching components to be the lazy motor you desire, it is workable. There is also the possibility of using the tuning itself to pull a bit of timng but again, then you are getting to a point that the inherent efficiencies of an engine design are not being used as designed and even removing a bit of timing can cause driveability issues if going too far.
I still believe you should define what it is you want and then either have that built bsed on the stock engine or if using an aftermarket built complete engine, get one that is built as close as possible to your wants.
This is a scatter-brained idea, I realise that, but it is worth sharing. I think it would be great to have a truly big motor, just for the sake of it. I have a giant purring pussycat in mind, rather than a starving sabre-tooth tiger! My use of the word 'lazy' was just my way of describing an engine that is not tuned for maximum performance - more a giant V107T, than a drag-motor.
Thinking through ideas out loud like this is a way of shaping and eventually defining something feasible that might just take wings eventually!
Did over 1/2 dozen 117" with a Wood 6, when the 96" first came out in 2007. Touring/trailer towing builds.
Our latest version of a 117" with a Wood 6, @ 10.2 cr, was tuned by Bruce, at HP Express.
118.5/134.8 in a Dyna.
Anther big/lazy combo is a 124"/Wood 408 cam combo.
Only have one of those in service.
Brutal torque off idle thoughout the rpm band, with 10.5 cr.
Scott
Scott
Is there a Wood cam that might provide a wide smooth torque band in a 145"? Or is that a dream too far! A bit less of the 'brutal' would be fine....
http://www.choppertownnation.com/vid...ibute-racebike
