Small exhaust leak with new slipon
Old Jul 22, 2010 | 05:21 PM
blawson's Avatar
blawson
Default Small exhaust leak with new slipon
I put some rush slipons on my heritage and I have been fighting with an exhaust leak where the slipons meet the head pipe. I got new clamps and cleaned the rough edges on the slipon and it did improve the leak, but its still there. I have tried different placement and really cranked that clamp down but just cant get it to go away.
Any tips or tricks I might try?
Old Jul 22, 2010 | 05:22 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
use some Ultra copper on the connection.
Drew
Old Jul 22, 2010 | 05:54 PM
nathanw's Avatar
nathanw
I've used it before with success.
Old Jul 22, 2010 | 05:59 PM
Iceman24's Avatar
Iceman24
Yep, HT silicone & make sure you haven't crimped the pipes. Slip-on should only slide right past the slot & then clamp on to torque spec. Hope it worked...
Old Jul 22, 2010 | 08:06 PM
blawson's Avatar
blawson
do you happen to know the proper torque?
Old Jul 22, 2010 | 08:48 PM
shineybike's Avatar
shineybike
I had the same problem with a set of rush slip-ons. I used the high-temp silicone and it worked. I found there were at least two brands, so I picked the one that had the highest temp rating.
Old Jul 22, 2010 | 09:03 PM
blawson's Avatar
blawson
just finished up, gonna let it cure and hopefully got it plugged. i torqued to about 45lbs.
it didn’t look like I did any damage to the head pipe by torquing to tight previously
I got the permatex ultra copper.. says its o2 sensor safe, and good to 700F
Old Jul 22, 2010 | 09:23 PM
07 dyna man's Avatar
07 dyna man
yep high temp silicone works well,, i put the clamps rite to edge of the mufflers and put silicone in the reliefs and torqued them down
Old Jul 23, 2010 | 09:09 AM
Rush Racing Products's Avatar
Crank it to 65 ft/lbs and if you still can't get it to seal please call our tech guys.
Our mufflers use a thicker ga steel than stock and require more torque on the clamp to get a good seal.
Old Jul 23, 2010 | 04:56 PM
blawson's Avatar
blawson
Thanks for the help, I think I managed to get it stopped. Checked it this morning and I could no longer feel the puffs, I still need to do the smoke test.
I torqued the rear to 60lbs with no problems after reading a post saying 45-60lbs of torque. When I did the front my clamp decided to break apart before I hit 60lbs. So I ended up going to 45lbs on the front (luckily I had a spare clamp!). I assume there is no reason to go any tighter as long as the leak has been stopped.
Dsrieth
Dec 20, 2017 10:49 AM
agm1563
Aug 8, 2009 11:44 PM
Qckfr
Apr 30, 2009 12:55 PM
ekcivic1
Feb 26, 2009 12:45 PM
mchaous
Apr 25, 2005 02:17 PM
