Performance filter
Old Sep 5, 2006 | 11:05 PM
Bpburke's Avatar
Bpburke
Stage IV
Default Performance filter
I just installed V & H BSS on my '06 Fatboy F/I. I'm hardly a wrench, but the install went smooth. I also picked up the V & H fuelpak. It says I need a performance air cleaner with the fuelpak, but I'm unsure if I need just a filter or if I should go with a whole kit. Any suggestions?
Old Sep 6, 2006 | 01:20 AM
PosseRider's Avatar
PosseRider
Default RE: Performance filter
Check out their 3909 kit just installed on mine . works good
Old Sep 6, 2006 | 01:50 AM
bobcowan's Avatar
bobcowan
With the engine otherwise stock, probably no need to run right out and spend $120 on a filter. Remove the football cover, and drill some 1" holes in the plastic backing plate. Put the footbal back one. If you're really worried about it, add some holes to the bottom of the football. You've now double the air flow capacity of the stock cover. And it was free.
You're still stuck with the stock small paper element. But if you havn't changed the cam or displacement, you don't really need to.
fmf979
May 4, 2012 10:30 PM
Expoacher
Apr 28, 2010 06:17 AM
stevieg
Oct 7, 2007 04:46 AM
tank69
Jun 24, 2007 09:41 PM
manowar
Aug 14, 2006 11:23 PM
