Sportster Jug Problem
Old Sep 14, 2010 | 08:52 AM
darkpye's Avatar
darkpye
5th Gear
One more question: J1mmy had told me in his post that the broken pieces probably fell off when I removed the carb. I did a flashlight check in the head and found nothing, however, I think it's possible that a piece or 2 could have been sucked into the cylinder when riding, and I should remove the head to check. Would I be in error if I didn't. Any thoughts? Thanks again, Rob
Old Sep 14, 2010 | 09:12 AM
darkpye's Avatar
darkpye
5th Gear
Forgot to mention that if I do remove the head should I replace the head gasket on one or both cylinders. Just a random thought that struck me when contemplating the head removal. And... one more question: Is the head made of cast iron, and if so, in the process of brazing, should the surrounding metal be heated to red hot? In the past, I was told by a welder friend of mine that when stick welding (not brazing) cast iron, the area to be welded must be heated to beet red. Don't really know if this is true or not, and if this procedure should be done when brazing? Rob
JackShafted
General Topics/Tech Tips
Oct 5, 2021 04:44 PM
VA3EPR
Aug 8, 2012 02:09 PM
marmalade
Oct 4, 2011 09:11 PM
Jefferson
Nov 20, 2009 07:19 PM
supr2nr
Ironhead
Jan 15, 2008 12:58 AM
