Sportster Jug Problem
Old Sep 6, 2010 | 09:10 AM
darkpye's Avatar
darkpye
5th Gear
Default Sportster Jug Problem
Hi List, This is my first post to this informative forum. That said, I hope someone will be able to come up with a solution to my dilemma. Took my 79' Sportster out from storage after 8 years, and started to do the necessary to bring her back to life. First started with the SU carb, and after removing the intake manifold from the cylinder, noticed that the left cylinder had some outer ring (rubber band type) breakage with the pieces no longer there, which consequently would not allow for a perfect seal between it and the intake manifold. Was wondering if I could take the bike to a weld shop (would not try it myself) to do a build up on the cylinder intake hole. Is this possible, or should I buy 2 brand new jugs. Any info as to what I should do, would be greatly appreciated. Hate to think I would have to buy 2 new jugs. Here's a pic of the problem: Thanks, Rob G
Old Sep 6, 2010 | 09:18 AM
darkpye's Avatar
darkpye
5th Gear
Whoops, on second thought, I better remove the motor from the frame, and unbolt & inspect the cylinder for broken pieces of cast iron. Don't want screw the pooch by ruining the jug walls. Rob G.
Old Sep 6, 2010 | 08:03 PM
TCMAN's Avatar
TCMAN
Just curious, how did the bike run before it went into storage? You might be able to get by with a temporary fix; piece of inner tube over the the existing o-ring seal before installing the band. By the way, no need to remove engine from the frame to remove the cylinders.
Old Sep 7, 2010 | 08:13 AM
darkpye's Avatar
darkpye
5th Gear
Thanks for the reply TCMAN. I don't know if I have enough clearance to remove the jug with the engine in place on the frame, but will give it a try. Concerning the rubber tire piece, do you think the engine heat will melt the rubber? Thanks again, rob g
Old Sep 9, 2010 | 04:17 PM
street racer's Avatar
street racer
I have seen people with this type of problem have brazed the damaged section then remachined it.Still going to have to remove the head,dissassemble it, have it cleaned before the brazing and machine work.It would still be cheaper than a used head.
Old Sep 9, 2010 | 10:37 PM
TCMAN's Avatar
TCMAN
The intake is one of the coolest spots on the head, a good air to fuel ratio and you shouldn't have any problems with the inner tube; I have done exactly that on an old Shovelhead Harley that I owned years ago, sure miss that bike!
Old Sep 9, 2010 | 11:43 PM
j1mmy's Avatar
j1mmy
that grove is for a o ring type of seal manifold, the newer ones used a wider rubberband seal that seals on the upper shoulder.. they make plastic rings (v-twin,custom chrome)that fill the grove then you use the rubberbad seals, using the retro fit mounts will take care of the chips and make it seal a lot better.no need to take it apart unless it has bad compression or anouther sign of problems..look in the head intake chamber for pieces or knicks from the cast iron pieces.they most likley fell on the ground and not in the head
Old Sep 12, 2010 | 09:09 AM
darkpye's Avatar
darkpye
5th Gear
Hi J1mmy,
Where would I get the plastic rings, and what should I ask for parts wise? I am getting ready to reinstall the manifold and the su carb after I check for the broken pieces inside the head. Thanks for the extra info - I can breathe easier.
Rob G.
Old Sep 13, 2010 | 05:27 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Brazing is how we would approach that repair here as well.
Scott
Old Sep 13, 2010 | 08:24 AM
Old Gunny's Avatar
Old Gunny
My Wife misses that old 73 Superglide we had, I miss it and both miss being 37 years younger.
