Head Gaskets
Old Sep 16, 2010 | 05:38 AM
darkpye's Avatar
darkpye
5th Gear
Default Head Gaskets
Which head gaskets are preferable, teflon or copper? I heard that with copper head gaskets, you should anneal them prior to placement. Should this be done, and if so, what is the procedure - red hot with water quenching? Thanks, Rob
Old Sep 16, 2010 | 09:21 AM
djl's Avatar
djl
Don't bother with either; Cometic MLS.
Old Sep 16, 2010 | 07:15 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
What djl said.
Those Cometics are the industry standard, for leak-free operation, and accurate squish dimensions.
We use nothing but those, here.
Scott
Old Sep 16, 2010 | 08:53 PM
inverse121's Avatar
inverse121
Scott,
Is there any special surface prep that needs to me done to use the MLS gaskets?
Old Sep 17, 2010 | 04:16 AM
Hillsidecycle.com
Sponsor
We generally glass bead the surfaces, but as long as it is void of any prior gasket material, your good to go.
Scott
Old Sep 17, 2010 | 10:20 PM
inverse121's Avatar
inverse121
I had heard to be very careful that the surfaces were absolutely flat had absolutely nothing left on them including fingerprints.
Old Sep 17, 2010 | 10:35 PM
mentor70's Avatar
mentor70
Cometic recomends a finish of 50 RA or finer for best results., and they mean it!
Old Sep 18, 2010 | 02:45 PM
SportsterBob's Avatar
SportsterBob
I blew a front head gasket 3.5 yrs ago from James Gaskets...Put in a set of S&S head/base gaskets with no issues...Followed the recommedations of no less than .055" squish for street use and installed them at .058" squish...Cleaned all gasket surfaces with lacquer thinner and used NO sealants......No regrets!!!
Used Cometic top-end gaskets on the Sporty with no regrets as well!!
Old Sep 19, 2010 | 09:39 AM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
Cometic here 100% for head gaskets.........
Old Sep 20, 2010 | 05:58 AM
Hillsidecycle.com
Sponsor
[quote=SportsterBob;7302014]I blew a front head gasket 3.5 yrs ago from James Gaskets...Put in a set of S&S head/base gaskets with no issues...Followed the recommedations of no less than .055" squish for street use and installed them at .058" squish...Cleaned all gasket surfaces with lacquer thinner and used NO sealants......No regrets!!!
We strive to establish .030" squish bands here, as the closer you put the piston to cylinder head, the more turbulent chamber you create, and much less detonation you'll experience, especially with todays fuel.
Scott
