Pushrod adjustment question
Old Dec 6, 2010 | 05:22 PM
jackinthebox's Avatar
jackinthebox
Default Pushrod adjustment question
On the se tapered pushrods what's the difference between 2 1/2 turns and 3. My indie says he goes 3 turns instead. He didnt really give me a reason. But how much of a diff does it make. I did a search and the most reason given was to quiet things down. Just tryin to learn here. Thx
Old Dec 6, 2010 | 06:16 PM
asm481's Avatar
asm481
It is 1/2 a turn difference.
Really do the three turns. It is a bit quieter as far as the sewing machine sound.
Old Dec 6, 2010 | 08:19 PM
djl's Avatar
djl
The thread pitch on those pushrods is 24TPI. Without going through the math, to determine how many turns will set the pushrod .100" into the lifter travel (the mid point), you divide by 10. So, 2.4 turns will get you there. So, 2.4 turns = .042" per turn, which means that 3 turns would set the pushrod .126" into the lifter travel.
Setting the pushrod a little below the midpoint increases the lifter preload and, many times, will reduce valve train noise. There is still about .075" of lifter travel remaining which is plenty.
Comprende?
TroubledWine
Engine Mechanical Topics
15
Apr 14, 2019 11:08 AM
ThisIsMe
Sep 1, 2014 07:43 PM
sctrucker
19
Oct 19, 2013 06:36 AM
remmag
May 28, 2011 04:39 PM
airchair10
Aug 23, 2010 09:05 AM
