Bored Cylinders
Old Dec 19, 2010 | 12:41 PM
Night Hog's Avatar
Night Hog
Default Bored Cylinders
I bought some bored out cylinders on Ebay that were supposed to be 3.875", then the guy told me that they were +.010 over. I told him ok because I hadnt bought my pistons yet. I measured the cylinders last night and they are measuring out 3.883" and 3.881". What is the acceptable amount allowed? I am afraid that these wont work. If not it would still be cheaper to by pistons and send them with my cyls to be bored and sell the ones I got on ebay. I could also send them out and make it a 98". I used some digital calipers I borrowed from work, what would be a better way to measure these? Thanks.
Old Dec 19, 2010 | 03:09 PM
mentor70's Avatar
mentor70
i would have a shop spec them out for sure, before you buy any pistons.
Old Dec 19, 2010 | 05:38 PM
djl's Avatar
djl
Meausring pistons is not something one can do accurately with dial calipers. The cylinders have to be measured at an X and Y axis and a 45* axis between X and Y; eight points at the top, mid and bottom of the piston travel. Meaurements are done with a dial bore guage and the cylinders in torque plates; checking for roundness and taper.
In your situation, if you want to run forged pistons, you could buy a set of JE pistons and have a "qualified" machinist hone the cylinders to fit those pistons. I happen to prefer cast pistons but I don't think anyone makes cast pistons for a 3.932" (98" bore). Or, you could have the machinist verify the bore and buy a set of SE flat top pistons, .020" over size and have the cylinders honed to fit.
Just a tip for future reference, it's not real smart to buy a set of cylinders before buying pistons, particularly off Ebay. Good luck.
Old Dec 19, 2010 | 05:50 PM
wurk_truk's Avatar
wurk_truk
You can send them to Hillside or Hyperformace and they can bore them and fit with 3.932 pistons and that will make you a 98. .... of course you could have done this with the cylinders you have on the bike already... bore to a 95 or a 98 piston. Cylinders are cheap. Hope you didn't pay too much.
Old Dec 19, 2010 | 09:40 PM
Night Hog's Avatar
Night Hog
I agree 100%, but for 100 bucks, it was worth a chance. I did my research 1st and found that this company was very reputable and has done a few magazine articles and alot of people here have used them. $133 with shipping.
Old Dec 20, 2010 | 06:11 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Micrometers are needed, as well as a dial bore guage, to set them up correctly.
Scott
Old Dec 20, 2010 | 09:44 AM
Bad Disposition's Avatar
Bad Disposition
All, my Diamond cut 103 CI juggs with installed 10:5:1 CP pistons are still up for grabs. Someone needs a good Christmas present.
BD
Old Dec 20, 2010 | 11:55 AM
BlackFatBob64's Avatar
BlackFatBob64
Not only do you need inside micrometers to measure cylinder bore. HD jugs have to be in torque plates and torgued to spec before you will get a correct measurement. At least that is true fore EVO and TC jugs. Some places like nrhsp will fit pistons to your cylinders if you need help.
http://www.nrhsperformance.com/tech_squish.shtml
Old Dec 20, 2010 | 12:58 PM
djl's Avatar
djl
See #3; not just HD jugs.
Old Dec 20, 2010 | 01:50 PM
chevele72's Avatar
chevele72
I bought a set of 88" jugs off e-bay that had 1k miles on them for $ 65. and Scott just turned them into 98"
