Good Deal?
Old Jan 27, 2011 | 03:25 PM
pilgrim08's Avatar
pilgrim08
Default Good Deal?
Just got an estimate for a set of 204 cams, se race tuner, and a dyno tune.
$1390.00
Is that good? Free tune and pick up.
Old Jan 27, 2011 | 05:10 PM
roadkingharry's Avatar
roadkingharry
Not so much. The cam at Zanotti's would be around $240. Couple hundred for the race tuner (is your bike carbed?), around $150 + or - for the adj. push rods depending on the brand, another $50 at most for gaskets. $750 for labor and tune? I'm at $900.00 with 95" SE flat tops, cylinders, andrews 26a,Timken inners,baisley spring, some head work from Hillside, gaskets, jets and a few tools.
Old Jan 28, 2011 | 03:40 PM
pilgrim08's Avatar
pilgrim08
That's what I thought. I think I will start to order the parts online from Zanotti's and then look into the labor. Thank you.
Old Jan 28, 2011 | 10:56 PM
beaureed445's Avatar
beaureed445
Race tuner- $400ish
Tune- $300ish
Labor to change cams- 4 hrs @ $/ hr (say $75/hr)
Adj Pushrods- $150
Cams- $250ish
Gaskets, Lube, etc- $100
Are they upgrading your inner cam bearings to Torringtons? That'll run you an extra $15.00!
I don't think the tune is "free." They're probably willing to throw a canned map in there for you if you buy everything else from them.
Old Jan 29, 2011 | 08:04 AM
troop's Avatar
troop
In my area the dealers charge $70/hr. I was quoted 4@$70 = $280 This included pulling the rocker boxes so the stock pushrods can be used. Tune was estimated at $245 (3hrs). Ebay can be a good place to look for gasket kits too. Cometics can be found for a reasonable price. I got a new SEPST on ebay for $226. Worth a try....
Old Jan 29, 2011 | 08:18 AM
imrotton2's Avatar
imrotton2
$1390.00
why the 204 cams???? get somthing that will wake it up
sgr60
Jan 1, 2023 09:11 PM
ga4boats
Oct 6, 2020 07:59 PM
sharkey
Mar 23, 2015 09:11 AM
gatorlaw
Jan 11, 2013 07:37 AM
Pete6114
Feb 16, 2012 07:46 PM
