Tuning after cam install?
Old Oct 9, 2017 | 01:54 AM
sgr60's Avatar
sgr60
Default Tuning after cam install?
Thought I’d throw this question out there -
I’m planning to put Andrews 57h cams in my 2012 FLHX pretty soon, and I’m wondering about the cost/benefit of tuning options after the new cams are in.
I currently have the SE super tuner, and I’m wondering whether I should look to get the bike dyno tuned using that tuner, or purchase a new tuner (likely from Fuel Moto) with a custom map (and skip the dyno)?
Old Oct 9, 2017 | 02:46 AM
MTBIG G's Avatar
MTBIG G
Been down the same road with an 11 flhtk, andrews 54h cams, .030 cometic head gasket, xpipe-v&h ovals, s&s oil pump, cam plate, etc. Used a custom map and tts tuner exact for my setup and no matter how much I messed with it, I never could get the tune right on my own.
Half day at the dyno with an experienced tuner (not me) and the bike ran amazing.
Highly recommend getting a dyno tune using your super tuner. Plus you'll save money!
Old Oct 9, 2017 | 10:38 AM
eaglefan1's Avatar
eaglefan1
Get it tuned by a good tuner. You will be glad you did
Old Oct 9, 2017 | 11:01 AM
0ldhippie's Avatar
0ldhippie
Having done it all (basic tuners, canned maps from fuel moto and Dynajet, “auto tunes” many times) nothing beats a proper Dyno tune by someone who knows what they are doing. Not sure your SE tuner is supported or useable anymore?
Old Oct 9, 2017 | 01:03 PM
sgr60's Avatar
sgr60
I was thinking that this might be an issue - most dyno places that I’ve found mention that they want to use a PC tuner so I was wondering if I’d be able to get it done using the Super Tuner. Hoping someone may have some insight on that?
Old Oct 9, 2017 | 01:53 PM
hattitude's Avatar
hattitude
I use canned maps and a PowerVision tuner with Auto Tune Pro to dial in maps, ONLY, because I know of no good tuners within a days drive of my home...
If you know/can find a good dyno tuner in your area... than by all means use them... also, let them tune the bike with whatever tuner they feel most comfortable with....
If they give you a choice of tuner, and the PowerVision is one of them, I would use the PV... it can be changed/added to numerous other bikes, can be used as a DTC reader on any bike, doesn't lock your tune/ECM, and it's fairly easy to use...
Good luck..
Old Oct 9, 2017 | 02:22 PM
jt metal's Avatar
jt metal
Pv from Fm.....bike ran great. Then I tried a Dyno tune. Unbelievable. Almost night & day.......
Old Oct 9, 2017 | 02:35 PM
Pumba11's Avatar
Pumba11
Yep I had mine tuned. The indy road it around and tweaked the carb.
Old Oct 9, 2017 | 02:49 PM
seanl's Avatar
seanl
That's amazing. I have a really nice map from FM and my bike runs great. I just didn't think there' a lot left on the table, yet I keep seeing posts like yours which make me think I should get the bike tuned, we have well known tuner on the other side of the Bay.
Do you have a before and after graph?
Old Oct 9, 2017 | 03:33 PM
B Bop's Avatar
B Bop
If you are looking for a plug & play fuel tuner, and don't like to downloading maps, or dyno tunes, then read on!
After installing 57h cams my auto tuner made adjustments 80 times a second automatically, every time I ride.
https://www.hdforums.com/forum/touri...other-day.html
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo (stage II)
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
A politician is a fellow who will lay down “your” life for his country.
