High engine Idle
Old Feb 9, 2011 | 08:48 AM
Biggie's Avatar
Biggie
Default High engine Idle
My 2004 Ultra started idling at 2500-3000 Rpms when at Stoplights. When you first start up everything is fine at 1000 rpm's. After 30 miles or so is when it starts to run fast when it should be idling at 1000 Rpms. I checked and oiled cables but still have this problem. Anyone know what could be causing it.
Old Feb 9, 2011 | 09:18 PM
evostroker's Avatar
evostroker
You need to check for a vacuum leak.Have the bike running and spray a little WD 40 on the intake manifold..If the idle changes you have an intake leak
Old Feb 9, 2011 | 09:31 PM
Biggie's Avatar
Biggie
Thanks. I'll try that.
Old Feb 9, 2011 | 11:42 PM
Lonewolf176's Avatar
Lonewolf176
If it's efi check the tps.
Old May 4, 2011 | 04:41 PM
Skeezix2's Avatar
Skeezix2
1st Gear
Sounds like the same issue I'm having, how did you solve it?
gbuss5
Jul 14, 2015 09:42 AM
Jerry Nokes
Engine Mechanical Topics
Oct 29, 2014 09:50 PM
fiscomi
May 17, 2013 01:39 PM
Ultraredone
Oct 2, 2009 10:25 AM
Chief101
Oct 15, 2006 03:41 PM
