Is this a problem?
Old Jun 29, 2005 | 06:34 PM
Old Skool's Avatar
Old Skool
Default Is this a problem?
Howdy -
I just did a dual exhaust conversion on my '05 FLSTNI (Deluxe). The dual cross-over exhaust pipe slightly touches the ignition coil cover on the drive side of the bike. Accordingly, the cover heats up while riding. Will this lead to any problems down the road???
The rest of the exhaust looks like it fits properly (i.e. down pipe routes nicely along outer primary cover).
Thanks for your help!
Leo
Old Jun 29, 2005 | 07:05 PM
billnourse's Avatar
billnourse
Default RE: Is this a problem?
Leo,
I would not want anything rubbing against the coil cover. The exhaust could cause excessive heat and do damage to the coil, plus, there could be a vibration problem that could do damage.
Regards,
Bill
Old Jun 29, 2005 | 09:52 PM
John TN's Avatar
John TN
I agree with Bill, you might try to loosen the flange bolts as well as the crossover and see if you can get more clearance, most times you can.
John TN
Old Jun 30, 2005 | 12:35 AM
Old Skool's Avatar
Old Skool
Yikes! Back to the dealer first thing in the morning tomorrow! Bill, John - thanks for your assessments! Will let you know when it's fixed.
Cheers,
Leo
Old Jun 30, 2005 | 06:17 PM
Old Skool's Avatar
Old Skool
Problem fixed! Now it clears the ignition coil cover but only by several mm's...at least it's not touching now. They even managed to straighten the end caps (they were slightly tilted in the same direction before).
Thanks again, and safe riding!
Leo
bdtaylor1979
Jun 21, 2019 10:49 PM
jim70
Shovelhead
May 24, 2013 01:58 PM
tekeum
Jan 31, 2010 08:53 AM
Trek
Aug 10, 2008 09:59 PM
mariner227
Jan 8, 2007 11:14 PM
