Checking Crank run out
Old Mar 23, 2011 | 11:41 PM
wurk_truk's Avatar
wurk_truk
Click HERE. Download and save. THEN you can watch the actual MOCO recommendations on HOW one is to check crank run out.... VIDEO!!!
This is the PDF of the Harley Bulletin on HOW to properly check crank run out. Proper crank run out is checked on BOTH SIDES and not just the cam plate side. My crank... when I pulled it out (09 SG with 18k), had .0045 on cam side and .008 on output side. MOCO says .012 is the limit... I call BS on that.....
THAT .008 would put my hands asleep after a few hours.
Having had a crank twist on on a stock bike... I STILL do NOT feel that it is a big problem as it would seem. Internet blows crap out of proportion quite a bit. 99 44/100% of folks will be fine. It is GOOD practice, though... when the cam chest is open... simply check. Easy to do.
NOW... my crank has .0005 runout, I have 20k on the new crank... and all is GOOD!!
Old Mar 24, 2011 | 05:35 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Originally Posted by 2black1s
Hey Scott,
Just to get a handle on how bad this crank runout issue really is, what percentage of cranks that you check measure out-of-spec?
Factory spec that is. What is desireable, and whether the factory spec is too lenient, is another discussion.
Thanks.
Most cranks we see are in/around .002"-.0035", but these are mostly late model bikes.
Very seldom are they as bad as the scare that has run rampant throughout these message boards.
The family of cranks that we witnessed with problems seemed to be the 03-05 units.
Saw an 04 once with about .023" on the pinion, and .042" on the sprocket side.
That was a rockin' 95"er we built him, in 05. He beat on that bike like a rented mule, and it finally showed up.
Very surprised it didn't rip the teeth off the gear drive set-up.
A 4 5/8" S&S crank, with an Axtell 4 1/8" cylinder kit fixed it.
Scott
Old Mar 24, 2011 | 06:16 AM
grbrown's Avatar
grbrown
Thumbs up
Scott
Sounds like good medicine!
Old Mar 24, 2011 | 10:59 AM
2black1s's Avatar
2black1s
Scott
Thanks! Some sanity to quench the concerns. With all of the bikes on the road I doubted it couldn't be as rampant as some internet threads might lead you to believe.
Old Mar 24, 2011 | 11:06 AM
grbrown's Avatar
grbrown
The internet is rather like a still. It concentrates both good and bad stuff!
TCMAN
Jun 13, 2021 11:02 AM
Ranger Rick
Jul 4, 2016 06:44 PM
BadBagger08
Sep 17, 2011 02:24 PM
DR. V-TWIN
Nov 21, 2010 03:54 PM
Meathooks
Jan 23, 2006 07:53 AM
