Need to rent: Inner Cam Bearing Puller
Old Mar 23, 2011 | 03:27 PM
notrailers's Avatar
notrailers
Default Need to rent: Inner Cam Bearing Puller
Do you have the tools to pull and install the inner cam bearings on 96" motor? I'd to borrow, rent or steal one.
Thanks !
Old Mar 23, 2011 | 03:52 PM
Wild Grover's Avatar
Wild Grover
AutoZone and such for pretty much free.....
Old Mar 23, 2011 | 04:58 PM
Mike T's Avatar
Mike T
+1 ask for a blind hole bearing puller. Give them a deposit, use it, take it back. You can't beat that deal.
Old Mar 23, 2011 | 11:55 PM
BadBagger08's Avatar
BadBagger08
Auto Zone. Don't do it. Go buy a Gorges Garage puller then resell it. I'm giving you forewarning that the Blind hole unit that you can rent from auto zone you can damage the old bearings when pulling and needles can then fall out inside your case.
I'm telling you this cause I recently had this happen to me. I was able retrieve 2 lost needle bearings that fell inside my crank case because I have my top end off and some cleaver ingenuity, by blowing air down the side of the crank while holding a pocket magnet at the bottom of the case allowed me to retrieve the lost needles.
Don't do it. spend the extra couple of bucks. My puller from GG was 110.0 shipped I then resold it for 85.00 well worth the 25.00 for the tool rental.
I was going to do a thread on this subject just haven't brought myself to it yet, and was concerned about the negative criticism I may get. I will post pics of my bearings tomorrow.
Jim
Old Mar 24, 2011 | 06:19 AM
Mike T's Avatar
Mike T
Jim
That's an easy fix. Put some grease in that old bearing before you pull it. Let's see the needles fall out now.
jenius308
Engine Mechanical Topics
11
Nov 22, 2021 08:46 AM
galaxyfe
Jul 30, 2015 12:03 PM
sagebrush1976
Feb 17, 2011 09:47 AM
wadejesu
Jan 9, 2008 11:53 AM
Taterdog
Nov 11, 2007 08:50 AM
