Looks like all cam gear drive kits come with Torrington inner cam bearings. Since I have a 2000 FLHTCI which I believe already has this style inner cam bearing, does it need to be replaced when I replace my cams? I know it makes sense, but another set of tools to buy just to pull and replace the inner bearings which are probably fine anyway.
You are better off doing it while the bike is apart, it's very easy to do. Go to your local AutoZone store and borrow their "blind spot puller", that will remove the inner cam bearings..........and it's free. Then to install the new bearings, just take a socket that is the same exact size as the out race of the bearing and put an extension on it.........then tap the bearing in place with the socket/extension and a hammer.
Like MUC said. Also, make sure you install the bearings the correct way. It's been a while, but I'm pretty sure the letters on the bearing cage face out. Check the install instructions.
Steve
Thanks, Steve, didn't know you could do it that way without damaging the bearing. I guess you'd want to be sure and not tap it in TOO far. That could be a problem.
Your 2002 inner bearings are not Toringtons. They are INA's. Swap them. The Toringtons are better bearings.
I used a correct puller for the job. However, I have an indy buddy that yanks them out with a blind puller and never seems to have a problem. However, you gotta be careful. If you bust one of them open and the rollers fall down inside your crankcase, you are screwed. My buddy also taps them into place. He uses a plastic/brass hammer. I wouldn't do it, but it works for him.
Dawg, isn't it possible to push the bearings too far into the casing? Maybe I don't know what I'm looking at, but looks like yours are closed off on the inside. Great pic, BTW.
xxx, I've got a 2000 like yours, not a 2002, so they should be Torrington's.
