Front Engine Mount Question
Old Oct 17, 2006 | 05:00 PM
Steve On 3's Avatar
Steve On 3
Default Front Engine Mount Question
Ok, the basics , I have a 95 Ultra . When changing my front motor mount .(Non HD Part) I noticed that the hole in the mount was much larger than the bolt on my bike. Looking at TCSD's excelent tech tip, it seems to show a metallic sleeve that would appear to go into the mount and would probably take up all the play between my 3/8 bolt and the motor mount. Again, this is HD's own tech bulletin. My HD parts manual does not list this sleeve in the drawings. IS there actually a sleeve or is the HD tech bulletin wrong? I'm getting a noise I can't identify down low and am trying to eliminate any and all sources. Since I'm not the original owner and I know the engine had been out of the frame at one point, Did the PO lose the sleeve? If so, where can I get one since my parts manual doesn't show one?
Thanks for your help
Bubba
Old Oct 17, 2006 | 05:10 PM
dawg's Avatar
dawg
Default RE: Front Engine Mount Question
HD replaced the motor mounts starting in 06. They do not have the sleeves in them. The new # is 16207-79C and is $28.03 at Zanotti's. If you are looking for just a sleeve check Home Depot or a hardware store for one the same length and diameter that you need.
Old Oct 18, 2006 | 04:19 PM
Steve On 3's Avatar
Steve On 3
Thanks Dawg. I'll probably look at home depot
Bubba
steelerdude1
Aug 6, 2015 08:31 AM
McMurphy
Jul 24, 2013 08:23 AM
NoTyme
Apr 27, 2011 01:26 PM
Don W.
Apr 10, 2009 09:14 PM
jus2anoyu
Nov 26, 2008 01:23 PM
