Baptism By Fire
Old Oct 28, 2006 | 08:04 AM
Sleeps In Trees's Avatar
Sleeps In Trees
Default Baptism By Fire
Fresh 1550 build (approx 3K miles) & I finally got an appt w/the dyno-guy today. This is my very first build, so I'm a little anxious...so many WOT runs may be a little hard on my engine, but if she makes it thru this will show durability & should be good to go for awhile. DJ250 w/TL along w/my PCIII usb should give a good tune & I'm hoping for 90HP/95TQ w/the TQ coming on early w/the very linear 'curve' the FC is known for. I have 190frt/188rear ccp & the build components are:
Big Boyz heads
SE 1550 cast FT pistons
Bored stock jugs
TW26G cams
SE Adj p-rods
D&D Fatcats
PC III usb
K&N RK-3909 AC
Y'all keep your fingers crossed for me[sm=insomnia.gif]
VicW.
Old Oct 28, 2006 | 11:12 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: Baptism By Fire
#1 why do you need so many WOT runs?
#2 I certainly hope he is going to adjust all your low speed, cruise etc as well.
#3 Have fun with it!
Old Oct 29, 2006 | 07:40 AM
Bryan TTM's Avatar
Bryan TTM
you'll make high 90's on both...if its built right, it'll run right and wont explode under the load....SERT tuning requires it to be run, read, adjusted, loaded, & run again to check...many times...lots of diff throttle positions, loads, & other parameters...SERT is much more labor intensive and takes time to get right....mine survived...now i never worry bout it cause of what it went thru
Old Oct 29, 2006 | 09:11 AM
Sleeps In Trees
Well, bike made it thru almost 5 hrs of tuning but never did make decent power - #'s are WAY off. I have a problem somewhere...
VicW.
Old Oct 29, 2006 | 12:06 PM
Bryan TTM's Avatar
Bryan TTM
sumpin maybe...pm me the #'s
Dbstglide
26
Apr 21, 2015 12:17 PM
62pan
Jan 30, 2010 06:54 PM
I CUT 1
Jan 14, 2009 06:37 PM
equandt
Apr 30, 2008 02:39 PM
KBES BAGGER
Apr 6, 2006 03:30 AM
