need help
Old Jun 12, 2011 | 01:06 PM
nmm's Avatar
nmm
1st Gear
Default need help
i have an 01 duece w/ 257 cams se heads 10.5 forged pistons, my question is can i replace the cams w/se258 cams or am i going to run into problems w/ clearance only duration is different, reason im doing this is a lifter got stuck and wiped out the roller bearing and cam on front cylinder so i have to replace but i have a new set of 258 cams so any help would be great
Old Jun 12, 2011 | 01:55 PM
bigjoe1's Avatar
bigjoe1
Really can't say for sure. If you knew what kind of clearance you had with the 257's it would be easier as the 258's have .011" more intake lift and .008" exhaust lift at TDC. At .224" intake and .208" I would definitely be checking. Also the 258's are gonna like abit more compression as the intake closes 4 degrees later the the 257.
HDSAE60
Engine Mechanical Topics
Jun 27, 2017 07:34 PM
Fxdxt-I
Feb 5, 2013 07:30 AM
CigarDogHD
Aug 6, 2011 09:47 AM
nmm
Jun 12, 2011 03:51 PM
cryan9
Jun 12, 2010 12:47 AM
