Question is: Does high octane fuel burn faster or slower than low octane fuel?
Keep in mind I'm asking about street fuel, street fuel as purchased at your local service station.
For the best performance, use the lowest octane that doesn't cause pinging (detonation). The lowest octane has has a lower flash point, meaning it burns quicker and more efficient. Higher compression motors need more octane to prevent pinging, or detonation, which can bend connecting rods and possibly damage cranks in high performance motors. My HD likes 93 while the 'Busa loves 87.
Yup, I need 92+ in my HD, but I've owned a long list of sportbikes that I never ran anything but 87 in them.
I've owned sport bikes to and ran low octane on 14:1 engine.
you can due that because of the cam timing. Bleeds off enough cylinder pressure to make a 14:1 engine have 170 psi in the cylinder when cranking. Of course they also red line at 14,000 rpm. : 0
